Question about Proscan 32LA25Q 32 in. LCD TV
Proscan tv volium is hard to hear when i turn it up.
What can i do to correct this problum
    Sergeant:
  • 270 Answers
Change the sound settings to normal level
Posted on Jul 15, 2009
How can I program the Proscan remote to my Proscan TV?
If your Proscan remote is the correct model for use with your Proscan TV, no "programming" should be necessary.
Feb 22, 2016 | Proscan Televison & Video
32 in proscan lcd tv just turned on tv and colours were all distorted
Try hard reset, unplug TV, wait 10 min. and plug back in.
. You may have to reset your setup configuration back to how you preferred. hope this works for you
Jan 14, 2016 | Proscan 32LB30QD 32 in. LCD TV
When I go to INPUT the sereen says: VIDEO LOCKED
Hell My Sansui Hard rock 21 eye tv has been chennal & voliume locked.
or remot not working tv screen small
Aug 25, 2011 | Sansui D 27" TV275 TV
Our proscan 1080p wont turn on with the remote. Any ideas??
Dead batteries in the remote ? Is it a universal remote correct component selected ? Will the set turn on at the TV power button ? Hard to say with such a vague description. These should give you more information to interject.
Jan 02, 2010 | Proscan 42LA45H 42 in. LCD TV
Volume making humming noise when on
there is a bad ground.
the hum you are hearing is ac getting into the audio.check all the rca plugs on the set are plugged in all the way.do not run them close to a power bar either.
sometimes a second unit with it's own volume is hooked up to the tv and then the tv volume is up too high because the other box is turned down.if there is a unit hooked up,turn it's volume up ,and the volume on the tv down,otherwise the tv will amplify the residual noise.cheers,ed
Jul 04, 2009 | Proscan 32LB30H LCD TV
Program Directv remote to operate the Proscan TV
The Proscan is an RCA product so the codes are:
10047, 10466, 11347, 11447, 10018, 10019, 10038, 10047, 1090, 1135, 10679, 11047, 11147, 11247, 11347, 11447, 11547
1. Turn on the TV
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under TV flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of TV being set up. If performed correctly, the green light under the selected position lashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
If this helps please rate my response. Have a wonderful day!!
Jun 27, 2009 | Proscan Televison & Video
Proscan 40' 40LC45S has a high pitched hum when it is off. Sound goes away when TV is on.
Same problem here, there is a high-pitched sound in standby. As soon as the light turns blue and the TV is on it's gone. I actually exchanged this TV three times at Best Buy but all the models made the same buzz in standby. I was told that it's normal and in the store you can't hear it since there is too much humming from other TVs around. The power is transformed down to a minimum, just for the remote controls, internal clock etc. and this causes the buzz, like when you dim your lights at home. I hooked it up to a surge-protector for clean power and just switch it off over night. During the day it's hard to hear anyway. - Again, since this is my third (!) Proscan 40' exchange I can definitely say that this is normal for this model. I was just surprised that nobody mentioned the same problem so far on the Best Buy reviews.
Jun 10, 2009 | Proscan 42LA30H 42 in. LCD Television
Tv problem
what chassis is in your set,look at the rear panel for model and chasis type to help to diagnose fault
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
Proscan 32LA25Q 32 in. LCD TV Logo
60 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
