NO DRAIN ''nd'' error MESSAGE
Water not draining at all, machine starts, spins, everything else seems fine except above problem.
-Cleaned all the hoses
-Took out the pump and cleaned it completely
Any suggestion would be greatly appreciated.
Regards
Ather
  • 6,784 Answers
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Jul 15, 2009
Assistance with rectifying as to why my LG top loader stops once it gets to the spin cycle. Can someone assist?
Before the washer can start to spin it needs to drain the water from the drum. By you having to drain the water from the machine indicates that the drain operation is not happening. This in the majority of the cases is a bad drain motor.
Aug 26, 2015 | LG Washing Machines
Nd code, water left in tub with the nd error code. What could be the problem?
sounds like your fill tube has been flooded, there is a plastic tubing that detects water pressure of the water sounds like it has been removed and now has water in it, which is not letting it drain all the way because the vacuum is picking up it is empty when the spin cycle stops and why it stops open the machine if you havent already and look for it the hose and a float valve work together to stop water when full and shut off the pump when empty this seems to be your problem. this fill valve and if it has the fill tube make sure there is no fluid in it also.
Apr 23, 2015 | Washing Machines
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
Spin cycle (7min) starts, spin perfectly, try to let water go (doesn't work) then reset back to 7min... ND code does appear but not all the time
ND error code means no drain check the pump filter check the pump and check the drain line that goes from the oulet port coming out of the outter tub to the pump and also check the drain hose leaving the pump that goes out of your washer as well. If you have any further questions message me back I await your rely
Thank you,
Rick
Oct 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Final spin cycle I get sud error code or f2, water mostly drained but no spin. When I restart the spin cycle just starts to spin then stops, sounds like it drains some more water then makes a small...
Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
Error code nD, won't go into spin cycle
Is the Machine a FAV6800A or a FAV9800A?
Do you want to DIY the fix?
The nd error code = No Drain error code.
You could have drain line clog, an issue with the drain pump or a stuck pressure switch. Do you hear the machines drain pump turn on and pump out water before entering lnto the spin cycle? Is there water left in the tub with the nd error code? If you can provide feedback on the questions above I will help guide through the troubleshooting steps.
You will need the Service Manual to troubleshoot.
The FAV6800AW/FAV9800AW Service Manual for reference. Sears Parts Direct for reference.
Rich
Dec 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error "nd" trouble
Nd, means no drain... a blockage in the drain line from the tub. Access from the back panel, you can remove the hose from the machine and check for blockages... this would be on the tub side of the hose... take the hose loose from the machine and check for blockage at the tub. squeeze the hose to check for blockage within.
take the hose loose at the pump to check for blockage there as well... watch out for water ...be ready to mop... let me know how you do..
May 26, 2009 | Maytag MAH2400A Compact Front Load Washer
Washing Machines Logo
149 people viewed this question
Top Washing Machines Experts
