Question about Harman Kardon CDR30 2-Disc CD Recorder
I have a harmon kardon cdr 30 cd recorder. After a power outage the unit no longer turns on. A surge must have blown something.
  • conwaydonald Jul 21, 2009
    That didn't work, however after removing the cover I found an inline fuse. I replaced and it worked, thanks though.
  • 1,512 Answers
Hi
First thing to do is disconnect the unit from the mains supply for 15 mins to allow for a hardware reset,and then power it up and try again. If it does not come up, then the power supply has been damaged by a power surge associated with the outage. You may have no choice but to take the unit to an authorised HK repairer. Let me know how you get on with resetting the unit. Please take the time to rate this solution. Happy to talk to you more about it. Cheers
regards robotek
Posted on Jul 15, 2009
  • Graeme Ross
    Graeme Ross Jul 19, 2009
    How did you go with the reseting the unit?
  • Graeme Ross
    Graeme Ross Jul 21, 2009
    Thats fantastic to hear that you have resolved the problem. As a registered Electronics Tech, I generally do not advise people to remove covers as a first port of call to resolve a faulty peice of equipment. You struck it lucky with the fuse. So often these days, the expensive equipment protects the $0.20 :) Would have been my next suggestion to you to check for any blown fuses if you were prepared to get on the tools.
    Be sure that you have replaced the fuse with exactly the same type. A SloBlo or time lag fuse is generally used in mains primary circuits, and has a T in the rating info on the fuse, and printed to the board as well.
    Glad it worked out for you.
    regards
    Graeme
My hk cdr 30 no reading any digital audio inserted disc. otherwise everything
CD do not just read any types of files, the disc must contain only files compatible with the unit. Check your manual.
Jan 20, 2013 | Harman Kardon CDR30 2-Disc CD Recorder
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
I have a Harman Kardon crd20 and when trying to record i'm getting "no audio" what is the problem? And is it possible to get a manual?
"CRD20"
A simple web search, which you could do yourself, for "Harman Kardon CDR 20 manual" finds several.
http://www.retrevo.com/support/Harman-Kardon-CDR-20-CD-Players-manual/id/386dj191/t/2/
Look for "no audio" in the manual. It occurs twice.
Aug 27, 2011 | Harman Kardon CDR20 CD Player
I have a Harman Kardon cdr 30 that I use to burn my analog Vinyl and cassettes to cd. I have done this successfully for years. I recently got a reel to reel deck and unhooked all the components and moved...
try plugging the HK30 out to R2R in, R2R out to RECV in...RECV (you may need 2 rca "Y" connectors) tape out back HK30 & Cass
the "Y" connector needed is (2) 2 female to 1 male (connect both HK30 & Cass deck)
May 15, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
I have a Harman Kardon CDR 30 that I use to burn my analog Vinyl and cassettes to CD. I have done this successfully for years. I recently got a reel to reel deck and unhooked all the components and moved...
do you remember how your connection was before the RR tape deck? if so connect it back that same exact (when every thing was recording / playing) way as before....(you also need to purchase 4 gold tip "y" connector jacks (2 RCA female to 1 RCA male)) ... in / out jacks you just plug the cassette deck will be shared with the RR tape deck...just note you will not be able to record from cassette to RR tape or vice versa...but you will be record from all other sources...
feel free to rate the help
Mar 27, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
Voltage Spike / Power Surge Harman Kardon AVR 130
In this case is pretty hard to give a diagnostic. There are plenty of possibilities. It has to be seen by a tech
Apr 05, 2008 | Harman Kardon AVR 130 Receiver
Harman Kardon CDR30 2-Disc CD Recorder Logo
177 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
