Question about Sewing Machines
I need a manuel for my old newhome machine,model#731047455, i can thread the machine but the bobbin is bubbling and the tenison all wrong
  • 19 Answers
Www.janomestuff.com answer it all
Posted on Sep 16, 2009
Looking for the factory sitting for the tenisons
thread tensions are only a guide
you have to adjust the needle and bobbin tensions your self to suit the thread thickness being used.
one setting is not the same for different materials and threads.
correct tension is when the upper and lower threads are meeting in the centre of the material being sewed.
Apr 07, 2015 | Singer 14SH654
What bobbin do I need for a Newhome SX-2122
Janome
Here is a link to a YouTube video.
There are other links also that MAY offer some help.
Google
Mar 18, 2015 | Sewing Machines
Every time I use this machine something else is wrong with it :-(. Now the bobbin thread us bubbling up in the back of the material and there is a grinding sound as the needle hesitates to move. What
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Nov 09, 2014 | Williams Brother PC-420 PRW Limited...
New Home Type F threading bobbin take up
Perhaps one of these will help:
New Home Model 532 Sewing Machine Threading Diagram
New Home Model 2022 Machine Threading Diagram
Thread Bobbin on Newhome Sewing Machine
HINT: install a brand new needle. Remove the top thread from the machine. ALWAYS RAISE the presser foot and then rethread the top thread. The upper tension should start out set at the midway point. Use only fresh, good quality thread--AVOID old or bargain bin threads.
If the machine is threaded correctly top and bottom, but is still not catching the bobbin thread, then it's possible the machine is out of time. Search for sewing machine timing or take it for service.
Since it is an older mechanical machine, it is recommended to clean and oil the machine frequently. Oil Before using it if it has been in storage. If the machine is sticky, motor drags, etc., here's a good reference for getting it back in shape:
Wheel on right side that controls the needle up and down is very tight...
May 26, 2017 | New Home Sewing Machines
My Singer model 780 does not pick up the bobbin threat. How do I correct this/
Very old is a relative term. I'm not finding anything under 780 or 6410. So we need to identify your machine. Can you post a picture?
Not picking up bobbin thread is usually one of several things. 1. Wrong needle size, blunted needle, or improperly installed needle. 2. Timing is wrong.
Dec 06, 2012 | Sewing Machines
Kenmore sewing mechine
If it a problem on bottom you need to work on the top of machine. Try adjusting your top tenisons. Also rethread machine.
Sep 02, 2012 | Sewing Machines
My top thread keeps wrapping around bobbin case and jamming does anyone know how to fix this tyvm
try these suggestions
1.check needle to see if it bent-roll needle on flat surface & see if it roll true
2.check to see if thread is coming off thread take-up lever
3.check the thread tenison
4.check for lint in the bobbin case area
5.check for loose thread in the bobbin case area
6.check to see if the bobbin is bent or warped
Jul 28, 2010 | Singer 7442 Mechanical Sewing Machine
My machine will not pick up the bobbin thread
how long have you had the machine?
I don't see what kind of machine you have?
does the bobbin drop in from the top, side, bottom?
email me at
monis_gifts@bellsouth.net
tell me what kind of machine and model number you have
I'll see if I can help
Sep 02, 2009 | As Seen On TV Sewing Machines
Thread Breaks
Dear Sir / Madam, please get your book out and follow the threading instructions very carefully. I am certain that is your only problem.
Kindest Regards,
Cookey.
Jul 25, 2009 | Brother LS-1217 Mechanical Sewing Machine
Bobbin Threading
Divot on needle must be installed facing bobbin case.
Apr 24, 2017 | Consew 199R-2A Sewing Machine
Sewing Machines Logo
55 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
