The sirusxm radio cuts out for 1 second every 20 seconds in our bar. Located on Lexington /E 85th St in Manhattan
The radio cuts out for 1 second every 15-20 seconds at our bar on Lexington/85th St in Manhattan. Jim 917.363.1636
5 Related Answers
MaRobert
  • Posted on Dec 03, 2008
SOURCE: Amana Mod # ABB2223DEB Refrigerator
I found this problem addressed on applianceblog.com and per they recomended part # 67006166. My repairman ordered this part and it had been superseeded by an even newer version, # 10127429. He installed that newest version in late June 2008 and it has been great ever since. So for me # 10127429 was the answer. Hope this helps
tmandink
tmandink
  • 30 Answers
  • Posted on Aug 07, 2009
SOURCE: my stihl fs 350 cuts out
needs gas jet reset or poss.new one
Anonymous
  • 90 Answers
  • Posted on Apr 23, 2010
SOURCE: Kidde CO alarm keeps beeping every 15-20 seconds. How do i fix it
Try changing the batteries and cleaning it.
If that does not do the trick, you have to get it serviced/repaired.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Kenneth Lee Sr.
  • 597 Answers
  • Posted on May 20, 2010
SOURCE: Magnavox 50ML8105D 50 in. HDTV DLP TV: I cut my magnovox on and in 20 seconds it cuts off...
Contact Magnavox tech support
Anonymous
  • 122 Answers
  • Posted on Jun 06, 2010
SOURCE: 15 to 20 minutes fast per day
if your caliber is automatic 7s26b something is wrong with the hair spring try a seiko service center anyway isnt something that you can fix by yourself!beware!far away from jewelers and local battery changers and other monkey magicians!automatic watch calibers are delicate and they ruine them!
Where to find CODE if I know code no. radio audio 10\30.
Turn radio on or turn ignition on - radio will show a number of lines on screen. enter code with numbers pad one code number at a time until next flashing bar opens and wait 10-20 seconds. If failed start procedure from scratch.
How to get pass st math kickbox level 9?
Try the site below.
How do you pass kick box level 9 on st math
You can also check this out.
To pass the Kick Box level four at 50%, you just move one of the blue bars down to the bottom, many squares work, but I did bottom row, second box from the right. Next, put the other blue bar in the second row from the top and the second box from the right in that row and then hit go. For more information, visit http://www.pulsitemeter.com/pass/-pass-level-kickbox-st-math.html.
Radio cuts out
When it cuts out does the radio's display still work? Can you change channels but just not HEAR anything? Did you buy it from a private party or a dealer? Acura dealers may cover this under a warranty. Otherwise, time to join an Acura forum and look for answers there.
GL,
Td
ST - Is that the "Standby function"? - how to put it off?
On radio systems, ST means STEREO signal lost... check antenna.
3helpful
Where is the fruse for the left aux power connector below the radio -
The fuses for the auxilliary power outlets are located in the rear fuse panel located under the left second row seat.
The fuse for the console and two front outlets is fuse #46 (20 Amp) and is marked "AUX PWR 1"
The fuse for the rear power outlet is fuse #15 (20 Amp) and is marked "AUX PWR 2"
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
I have just changed the batteries in my key fob for my P reg. ford fiesta but it won't open the doors
Programming
When
How
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3-5 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds
2answers
Radio only plays for 1/2 second and then turns off.
Nevermind! My problem was fixed, I'm embarrassed to say, with new batteries. I had been told that the batteries in the radio were new when in fact they weren't. Thanks anyway.
-hwell97
4helpful
Reset keyless entry on 1998 honda civic
Okay, here goes-
1. Turn Key to on position.
2. Push and hold **valet button on the stock radio.
**Valet button is skinny bar located between am/fm & cd/tape buttons on stock radio.
Door locks will cycle one time.
3. Press any button on remote one time within 20 seconds. Door locks will cycle again.
4. To program up to 4 additional remotes repeat step 3 for each additonal remote.
5. Turn key off programming is complete.
Thanks for using Fixya, please rate if this helps :)
Top Sirius Satellite Radio Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
