Question about Peg Perego IGED1084 Santa Fe Train
The train sounds but there is no movement. battery been charged overnight.
  • 130 Answers
MAKE SURE CONNECTIN GOOD W/TRACKS THEN CHECK BATT.CONNECTIONS ALOT OF TIMES IT IS THE CONNECTION
Posted on Jul 15, 2009
I have a FOSSIL mens wristwatch model # AM3423. I recently had a watch repair person replace the battery. Battery type and charge confirmed. I received the watch used as a gift from a relative who was...
Quartz watches stop working most often for one of three reasons: (1) dead battery; (2) dirt in the gears blocking the train; and (3) a bad crystal. This is the order in which I typically troubleshoot watches.
If the watch isn't working after you change the battery, first check to see that the stem is fully pushed in. A watch movement can shift just enough inside the case that a stem sometimes looks pushed in, but isn't quite in far enough to re-engage the movement. Pull out and push in the stem a few times to see if that changes anything.
Next, assuming that the battery is indeed fine, look closely at the second hand. Is it moving at all, even a tiny bit? Hold the watch up to your ear. Is there any kind of "chunk" sound about once every second? If you can answer "yes" to either of these questions, a speck of dirt has gotten into the movement and is preventing the gears from moving freely. It doesn't take more than a a big spec of dust to cause this. Sometimes, advancing the time will move the gears enough to cause the dirt to fall out. Some watch repair places also have a special machine that spins the hands rapidly to blow out or compact any dirt in the train. It's usually not economically rational to have the movement professionally cleaned beyond this point.
Finally, if you don't hear anything coming from your watch, the battery is good, and the setting stem is pushed firmly and completely into the watch movement, you may have a bad quartz timing crystal. It does happen, and when it does, the only repair is to replace the entire watch movement. Sometimes, that's affordable; sometimes, it just doesn't make sense.
Sep 20, 2012 | Fossil AM3424 Wrist Watch
My Legacy Cab2 remote won't turn on. It has charged batteries and I just used it about 2 hours ago. Any suggestions?
i don't have a solution but i have the same problem. i have rechargeable batteries and charged them overnight. left the remove in the base (don't know if that was a mistake). put the batteries in the next day and when i tried to turn it on, the red light flashed a bit and then nothing. i tried letting the batteries "cool" per instructions and that didn't work. not sure what to do next except call lionel for advice.
Dec 17, 2010 | Lionel 14295 990 LEGACY Command Set V2
The charge light keeps blinking red and doesn.t turn green, even after hours of charging and a new battery
There are many possible scenarios as to why this might be the case. The most logical would be that the battery has trained itself to not register a charge, this is a common problems with cell phone batteries due to incorrect charging procedures. Go ahead and power cycle the phone (take the battery out and let it sit overnight), if this does not resolve the issue, go and purchase another battery (make sure it works with your phone model) and try charging that one. hope this helps.
Oct 13, 2010 | Cell Phones
My 05 harley night train is not turning over, it also makes a clicking noise. it is outside covered, but it has been below 20 degrees.
Charge the battery overnight and it should probably start the colder tempture will drain the battery faster. Id suggest getting a battery tender to keep it fully charged if you are keeping it out side all winter
Nov 01, 2009 | 2005 Harley Davidson FLSTSC - FLSTSCI...
My seiko stops overnight but works during the day
if the watch is solar power it may not be getting enough to last through the night. if it is battery powered it may just be stuck when in certin postion like upside down or somthing
Jun 03, 2009 | Seiko Kinetic watch
Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
May 28, 2009 | Learning Curve Toys Thomas the Tank Engine...
Peg Perego IGED1084 Santa Fe Train Logo
225 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
