Question about JVC KD-LH7R CD Player
My cd player isnt working the radio will work but dats about it?? Do i need to get a new one??
  • 1,512 Answers
Hi
It is likely that the optics are presenting a problem. This may be a simple as a layer of dust in the laser lens. Try a CD lens cleaner disc if you have one, but they are not that effective at the best of times. . Hand cleaning the lens is the best solution. If you are up to it, use a q tip (cotton bud) moistened with Windex glass cleaner,and to polish and clean the lens in a circular motion, then use a dry one to be sure that no smears are left. Then try again. Happy to answer any questions you may have about this procedure. Please rate this solution. Cheers.
regards robotek
Posted on Jul 15, 2009
Cd belt size
cd isnt working because the belt is broking. I need to now what size of belt do my radio use
Jan 22, 2014 | Lanzar Exclusive SD45MU 4.5 TFT Touch...
I replaced the battery in my car and the cd player dont work. but everything else works... is there some kind of program that i need to do
does the radio work or is it just the cd function if radio doesnt work you may need to take it to dealer for coding but if only the cd isnt working you may have a jammed cd
Jan 10, 2011 | 2002 Toyota Camry Solara
Following a flat battery, my cd player won't work.
You dont need a code if your radio is working but your cd isnt. You just need to reset the cd player by finding a little small indent on the face and push it in with a sharp pen, pencil or paper clip. Some reset buttons are also found when you remove the face of the radio. You will notice it when you see a little small round hole. Push it in for at least 2 or 3 secs
Apr 08, 2010 | JVC AM FM CD DET FACE CAR STEREO
How do I get my radio to work? All I hear is static and I just installed my sony xplood deck. My antena goes up and down every time i turn my stereo on but radio isnt working
Plug in the antenna jack into the antenna hole in back of radio. Depending on the car you may need an antenna adapter. Cars that need antenna adapters are VW's, Nissans, New Honda's.
Apr 06, 2010 | Sony Xplod CD Player w/MP3 Playback...
My cd dvd player stopped working? pc says working fine?
try switching the power cable attached to the cd / dvd player..it will have a code on (P1, P2, P3...) swap it with 1 that is not in use...change ribbon cable dats attached from the cd/dvd palyer to motherboard...do not place your hand on the motherboard. if these dont work buy a new cd / dvd player...
Dec 08, 2009 | Gateway Computers & Internet
05 Ford F150 Radio doesn't work.
I had the same problem and i brought a new ford oem cd player 2 times and my mechanic says its an electrical problem with some fords not the Cd player or the radio. So your cd player may not be junk, it may be electrical or wiring problem.
May 25, 2009 | 2005 Ford F-150
Proton jumbuck radio/cd removal & replacement with single DIN
take a flatblade and pry the panel that is clipped in around the radio.remove the 4 bolts holding in the radio.
May 23, 2009 | JVC Car Audio & Video
Need to know where to connect this last wire so i can play my new cd player in my truck
You need to find a wire under the dash that is a 12V switched wire, it is used to actually turn the radio on and off, normally works with the ignition switch.
May 11, 2009 | Car Audio & Video
Problems with car audio
you should plug in the new harness and meter the wires to make sure there is power on two of the wires one will always be powered for memory the other should be powered when ignition is on if both test ok then check the in line fuse links on the radio wire harness I hope this helps good luck....
Jan 10, 2009 | Sony Xplod CD Player w/MP3 Playback...
Monsoon raido Cd Error
just replaced my 2006 Pontiac G6 GT Monsoon 6 CD changer with an identical model pulled from a totaled car.How do I reprogram it so it works on my car.
Dec 14, 2008 | 2006 Pontiac G6
JVC KD-LH7R CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
