Question about HP Hewlett Packard LaserJet 3052 Printer
Paper gets jamed on the upper feeder and cant remove it.
Put it off and on and repeat until the jammed paper comes out. Pull the paper out as it comes out.
Posted on Jul 15, 2009
The light in the printer stays on bsay paper is jamed and theirs no paper stuck at all
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 22, 2011 | Lexmark X5495 Printer
Paper keeps turning and jaming up then it says paper jam or out of paper
Aug 22, 2011 | Lexmark X5470 All-In-One InkJet Printer
Paper jam. How do I get the paper out. my instructions don't tell what to do. This is HP Officejet J4680cAll in One
http://h10032.www1.hp.com/ctg/Manual/c01770356.pdf
Follow the instructions on how to "To clean the plastic strip inside the automatic document feeder" This is the closest you will be able to get to getting inside the paper feeder to check for the paper jam.
Feb 28, 2011 | HP Office Equipment & Supplies
Keeps jaming on the right every time
Follow this step to clear the jam
press the diamond shape button start button to eject the jammed paper. If the jammed paper is not ejected, go to the next step.
if the paper is stuck near the sheet feeder or output tray, gently pull it out.
If the paper is stuck inside Epson Stylus CX7800, press the power on button to turn it off. Open the scanner and remove any pepr inside including any torn pieces. Do not pu;; it backward beacuse this can damage the sheet feeder. Close the scanner, then turn the epson stylus CX78oo back on.
Nov 17, 2010 | Epson Stylus CX7800 All-In-One InkJet...
Paper james during scan,clicking sound in upper
Clicking sound is not a healthy sound, check if any gear wheel is damaged. Is the tray moving up properly? There are a few sensitive parts like the clutch, gears etc. If you cant fix it please call a trained technician, so that damage is minimal.
S. Mohan
Nov 04, 2009 | Canon CanoScan DR3020 Path-Through Scanner
Paper keeps jaming when trying to print fax it
If the jam is consistent with exiting the drum, there's a chance the drum isn't secure and is the paper is getting caught on the exposed area of the drum. If this isn't the case, there may be paper caught in the feeder wheels.
Oct 18, 2009 | Brother IntelliFAX 4100 Laser Fax
The paper does not feed properly.
Replace the paper feeder or the rollers on the paper feeder are not rolling ar getting jamed. You need to have this serviced or just get yourself another printer. Lexmark are what I call in my expert advice throw aways the better ones are epson,xerox,HP and so forth. Please leave positive rating and feedback thanks
Oct 09, 2009 | Lexmark X3480 All-In-One Printer
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP Hewlett Packard LaserJet 3052 Printer Logo
Seeker5211
Seeker5211
