Brother 350c
First printing a photo takes lots of ink , it depends on the color of the photo , cyan is blue which maybe consumed more in the printing or there changes that the ink may have dried in the cart hence your getting this error ,remove cart take damp paper towel and hold the paper on the place where ink comes out gently for 20 second ,make it does not touch copper contact it may damage the cart ,make sure you check the place where ink with dry paper its usually bottom of the cart and repeat the above step with dry paper towel and try to print if you get the same error then you need to replace the cart or you can contact brother support and get cart replaced , once cart is used you need print once in week to keep cart from drying, you can use any photo paper which is compatible with printer .
Good luck....
Good luck....
