Craftsman gas weedeater
Its a straight shaft weed wacker line trimmer and i am having troubles with it. it will not keep turning the head of it as soon as you set it down and i was wondering on how i can get it fixed seeing as i only paid 4.00 usd for it at a thrift store. the motor works good and this is the only damn problem, i have searched all over the internet for a repair manual and no one has one. so if you can tell me how to get the head to keep turnin and not stop then thanks.
  • pekachu Nov 17, 2007
    also if anyone can tell me of a good repair shop for a washer in nebraska i would much appriciate it. my washer will not use cold water at all in it and i had to switch it to the hot connection and am just woundering if its an easy fix or an expensive one.
    Problem Solver:
  • 6 Answers
The head is stripped from theshaft to go to the moter it comes apart just go and buy that piece from home depot
Posted on Oct 11, 2009
Why does my weed wacker burn white smoke
Posted on Jun 02, 2008
Craftsman weedwacker model 316711970
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
Jul 09, 2015 | Craftsman 29cc 4Cycle Straight Shaft...
Craftsman 4 cycle weed wacker throwing oil
check the oil and see if its over full the carb might be leaking fuel into the crankcase
Aug 08, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
Craftsman weed wacker wont start
have you drained out all the old fuel and tried fresh fuel gas is only good for 30days in small engines
Jun 08, 2012 | Craftsman WeedWacker Gas Trimmer 25cc...
How do you remove the complete string head from the shaft of a weedeater model 316 795001
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-316795001/0247/1503820/P0090470/00002
The parts diagram above shows part #25, that part located just behind the head should have a small hole in the side about 1/4" diameter. That hole lines up with another hole inside to stop the shaft from turning . You need to line up both holes visually then insert a small phillips screwdriver in through both holes, that will hold the shaft still while you turn the whole head assembly with your hand. When removing the head assembly it should turn counter clock wise,when looking at it from an operating position, meaning that the threads are left handed.
Jul 12, 2011 | Garden
Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Apr 13, 2010 | Craftsman 25cc Gas Line Trimmer
Weed wacker wont start
You do know my neighbor took her sears craftsman edger in and got a new one after a year. TAKE IT BACK!!!!!!!!
Jun 09, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman gas weedeater. Engine runs, but the head won't run
Cut 1/8" off outer (aluminum) shaft. Lube inner shaft with STP or heavy gear lube this will re-engage worn square drive .Replacing inner cable is un-necessary this is normal wear. Sears Master Tech BB
May 26, 2009 | Craftsman 25cc Gas Line Trimmer
Washing Machines Logo
566 people viewed this question
Top Washing Machines Experts
