Question about Behringer XM1800S Professional Microphone
Wires in the microphone at the point where you connect to the lead have come appart and i need to solder them back on, Black, red and white wires. Which in which order do i solder them onto the connecter to the lead
  • 1,512 Answers
There are many standards of microphone connectivity with 3 pin XLR (cannon) style plugs. It depends on where in the world you are as to the favoured standard,
Your microphone usesthe following::
Pin
1 ground (white) 2 +ve or hot (red) 3 -ve or return (black)
Another way to work out what wires connect to what, is to remove the cover of one of your XLR-XLR microphone cables exposing the connections it favours, plug the connector into the mics scoket , and use the connections to the cable guide you in resoldering the connections back on.
The same connections can be veiwed in the user manual here
Please rate this solution. Cheers
regards robotek
Posted on Jul 15, 2009
    Scholar:
  • 113 Answers
If its an xlr plug , Black/Earth to pin 1 , Red to pin 2, white to pin 3
Best of luck
NEED TO WIRE LESON MICROPHONE TO MAGNUM 257
Notice the black mic plug has the numbers it is solder by numbers. Used rosin core silver solder radio shack sells it.
Mic Wiring
Stock
1-Shield (ground)
2-Yellow (audio)
3-Red (transmit)
4-White (receive)
Astatic
1-Shield & Blue
2-White
3-Red
4-Black
Yellow NC
Turner Roadking 56
1-Shield & Red
2-White
3-Blue
4-Black
Yellow NC
Sadelta the is a BASE mic
1-Shield
2-White
3-Brown
4-Green
Oct 02, 2011 | Magnum 257 CB Radio
Wires broken off mic cartridge
Hello ,
the simple of knowing the connection is this , but when you open the mic you will see numbers on the terminal written 3, 2, 1.
this represent colour for the wires .
3 REPRESENT THE BLACK WIRE
2 REPRESENT THE RED WIRE
1 REPRESENT THE WHITE WIRE .
After soldering this should work.
Good luck...
Jun 07, 2010 | Astatic CTM-44MC Professional Microphone
I have a Hopkins Brake Control the pigtail colors are Red, White, Blue, Black. My 2008 Chevy 1500 pigtail colors are Red with a black strip, Light Blue with white strip, Dark Blue, Orange, White. How do i...
1. connect the red wire to the stop lamp switch lead on the brake control. Connect the other end of red wire to the stop lamp switch in the vehicle using the splice connector
2. connect the blue wire to the trailer brake lead on the brake control. Route the other end of the blue wire to the trailer connector at the back of the vehicle.
3. connect the white wire to the ground lead on the brake control. Route the other end of the white
wire to the vehicle’s battery. Use the ring connector to connect the white wire to the battery’s negative terminal.
4. connect the black wire to the power lead on the brake control. Route the other end of the black wire to the vehicle’s battery. Use the fuse assembly to connect the black wire to the battery’s positive terminal.
Oct 22, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Recently I dropped my Beta 87A mic and the 2 wires that connect the mic itself came disconnected from the mic. I want to know how to resolder the mic.Thanks in advance. Norbert
I take it they are the wires to the diaphragm not the cable (XLR) connector.Be very carefull when soldering the wires back on. A small solder iron with a pointed tip works best. The positve terminal should be marked with a small red dot.The red wire goes there and the black on the negative. Be carefull and take your time.
Apr 27, 2009 | Shure Beta 87A Microphone Microphone
Astatic 636L Wiring
how do I wire a d 104 to a keen wood tm 221a radio
Jan 19, 2009 | Astatic 636L Noise Canceling Microphone...
Battery leads
Can You state exactly what the toy is. Maker, Name, model, pictures, year of manufacture. Details help the research process.
But try this...
If talking about a circuit, look where all the solders are, You can sometimes find a solder point that doesn't have a smooth top it will look like something broke off. Find two of these...To tell the difference when you find them which wire goes where, the solder point that traces back to any capacitor ( a cylindrical component with two leads on its bottom that has a black strip down its side noting which lead is negative.) The black wire can be soldered back to the point that traces back to a negative lead. Then the positive (red) will go to the other one.
If this does not help see if you can upload a good quality pic of both sides of the circuit if possible.
Aug 18, 2008 | Toys
Wiring cartridge
The "Standard wiring" is: Red = Right Hot= R Green= Right Ground= RG White= Lefty Hot= L Blue= Left Ground = LG Black if used is "Ground" and should be connected to a seperate ground circuit. Seems to me you are missing a couple of solder points. Also try twisting the pairs together but not all 4 together; i.e.(red & grn) (White & blue) to reduce "hum". Hope this helps.
Jun 02, 2007 | Stanton STR8-100 Turntable
Gemini djm-1 gooseneck microphone repair question
No problem! 2=RED 3=Black 1=White The wire without a color is ground. It can be soldered to pin 1 if necessary. Hope this helps.
Nov 05, 2006 | Gemini Sound Products DJM-1 Microphone
Behringer XM1800S Professional Microphone Logo
285 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
