Question about Acer Aspire 4315 Notebook
Screen compleatly black - Acer Aspire 4315 Notebook
    President:
  • 942 Answers
Hi...
First steps is the easy steps, did you install the motherboard driver. If you've already installed the motherboard driver, but there is no display, that's the time to do a hard troubleshooting.
Now let's discuss what weshould do when the laptop seems to be booting up without problems, thehard drive spins appropriately, and we even hear the welcome sound ofthe operating system, but we have no display on the LCD panel.
The easiest and most foolproof method for testing your LCD screen is to hook up the laptop to an external monitor. If the video output onthe external monitor looks fine, this means that the problem is withthe video connector, with your LCD panel itself, or with the circuitrythat turns on the LCD.
What do we do? It allstarts with disassembling the notebook. Find the video connector on thesystem board (if the video is integrated on the motherboard) or on thevideo card that is attached to the motherboard. Try re-connecting thecables. You may as well locate the display connector on the back of theend LCD panel. Re-seat that one too. This way you can be sure that theproblem is not related to connections.
Every now and then theswitch located on the system board that turns the backlight of the LCDon and off can become stuck. If this is the problem then your LCD neverpowers on. There's a little switch that detects whether the screen ofyour notebook is open or closed. That's the one we're talking about.Try to push it down and hope it gets unstuck.
Disassemblingthe laptop to unstick this switch is an option, but sometimes you canget away with not taking it apart. Try lightly hitting that plasticswitch. But wait, this isn't the only possible cause, unfortunately.Re-seat the other connectors and cables that are present around the LCDpanel and the video on board (including the inverter).
Allof the aforementioned can usually be fixed, but let's not forget aboutthe screen itself. Sometimes the screen can become defective. Herewe'll enumerate a few scenarios where the screen has gone bad and mustbe replaced: lots of vertical lines or bands appearing on the screen;half of the screen works fine but the other half stays either black(blank) or really white; the output on the screen looks blurred andchanges to different patterns; and so forth. These are almost alwayssigns of a defective LCD panel.
However, if theoutput on the screen is nothing but garbage, such as incorrectly placedspecial characters, shadows around the characters, unknown randomlyplaced marks of different colors, distorted or ugly-looking geometricpatterns, or tiny little white dots all over the screen, then these arealmost always due to the system board or the connection between the LCDpanel and the video card. Re-seat the connectors.
Allin all, these are some of the most common hardware failures.Nevertheless, before we finish this part, let's name some of theothers that will be covered in the second segment of this guide, alongwith the promised system instability troubleshooting strategies. Theseinclude clicking noises coming from the HDD, which is the well-knownsymptom of a dying HDD. Thus, back up your important data as soon aspossible and order a replacement.
Suddenly overheating is also discussedthoroughly and may cause of shutting down.
Good luck !!!
Regards
PCmania
Posted on Jul 15, 2009
    Sergeant:
  • 259 Answers
Install the grafic driver and check the disply setting
Model 34288 robinair . Were is the weight . How do you do A filter change.
There is no Weight in the machine. Machine show Filter weight that you have been recover refrigerant from the vehicles since last filter change! After every 68KG/150LBS of refrigerant recovery you must change the Spin-no filter. The machine ( Model-34788 ) will lock-up when filter capacity reach to 68kg & you will not abel to access the machin till replace new the filter.
When the machine show the filter weight 68kg on screen just press YES key,then add the 10 Digit code of new filter ( Code is stick with evey filter). If the code is accepted then open the old filter & replace new one.Follow the on screen direction to compleat the process.
Note: Do not switch off the machine till compleat the filter change function.
Jul 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
Screen turns red to mutch to fix $$$$
This is a simple fix and not hard to do, first you must get the speaker grill off, usaly two screws on the bottom and they might be hidden under to caps, then remove the acsess cover from the front. From there you should see a control box with six controls, three on top of three,,,,One part label "screen" the other "focus" now turn the set on and tune to a input that HAS NO SIGNAL this should give you a black pix, probley not now but it's supose to be black. Now turn the ones marked screen , one at a time counter clockwise just a little to get the pix compleatly black, now starting with one color turn the control slowly clockwise till the color just appears then turn it back down till it just disapears (Black) do this for all three colors Now the set should runn
Dec 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony dlp with red tint
Dec 29, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a Sony KP57ws500 that the screen turns green and then goes into standby. then when in standby the standby light flashes eight times then pauses and then flashes eight times again in this pattern...
Dec 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Green screen, no picture. tv shuts off by it self after 30 sec
Dec 26, 2009 | Sony KP-51HW40 51" Rear Projection...
PSE TURNS ON CONTROLER LIGHTS UP ALL LIGHTS ON PS3 WORK BUT SCREEN ON TV STAYS COMPLEATLY BLACK ANY IDEA AS TO WHAT IT COULD BE?
Turn the PS3 on from the console by pressing the power button and holding it until you hear the first beep followed by a second beep. let it go after that. This resets the video to seek an active output on the console itself
Dec 10, 2009 | Sony Playstation 3 (PS3) Console
My screen goes almost compleatly black, like the backlight has turned off. i turn of the screen and waite a second befor i turn it back on and its fine, untill i stop using a program like work or internet...
ur power settings are giving u hard time try setting them in battery profile u are using set wait time before switching lcd off to 10 minutes or 20 minutes then see what happens lemme know if i can help more
Feb 19, 2009 | Acer Aspire M3641 Dual Core E2200 PC...
Black screen
I work at at a school, and we had the same problem. Turns out, it a Closed Captioning problem.
We found the manual, and it states that "If a large black box covers 80% of your screen, the Text mode is probably set. Press 'Closed Caption' to turn it off." The "Closed Caption" button is on the remote. If you don't have the remote (as in our case), you can go to "Closed Caption" in the menu, and pick something like C4 and T4. That stopped the black box for us.
Jun 09, 2008 | Televison & Video
White screen
ummm...im kinda having the same problem except mine is a black screen. if u find anything out about urs can u let me know please. fordgal0817@yahoo.com thanks
Nov 28, 2007 | Samsung Digimax A503 Digital Camera
Acer Aspire 4315 Notebook Logo
237 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
