Question about Canon PowerShot SX100 IS Digital Camera
Every time I switch it on it asks me to reset the date and time settings. The batteries are fine and I don't recall changing any setting to make it do this.
On the left hand side of the camera there is a little batter hatch, above a screw hole. It has a number written on it. Pull this out and replace the battery in it. This is the time and date battery.
Posted on Jul 20, 2009
Need to set just the time on a timex WR100M mens watch
SETTING
  1. First, find the regular time mode by pressing the MODE button until the time (with the date at the top) shows.
  2. Press & hold the SET button until the word ENTER disappears and is replaced by the word TIME. Release that button. You'll notice that at the top of the display, the words SET T1 or SET - T2. This is where you select between setting the 1st time zone or the 2nd time zone. Select between T1 or T2 by pressing the RECALL button or the STOP/RESET button.
  3. Press either the MODE or the START/SPLIT button. You'll notice that whatever is blinking is what you can change. You can make the changes by pressing either the RECALL or the STOP/RESET button. You can change the Seconds, the Hours, the Minutes, the Month, the Date, the Year, and choose between 12 hour (civilian) or 24 hour (military) time. If you keep MODE or START/SPLIT button, you will go through all the things you can change and start again at the beginning. The START/SPLIT button goes through these things forward, and the MODE goes through the backwards, so if you pass something and want to back up, just switch buttons. In the same way, the RECALL changes things by making them larger, and STOP/RESET changes them by making them smaller, so if you accidentally pass the number you're trying to set it to, just switch to the other button and go back.
EXAMPLE OF SETTING THE WATCH Suppose you want to set the hours and the date in the 2nd Time Zone. (Just as an example, but setting any other time or date settings would be the same.)
  1. Press the lower left button on the side (MODE) until you see the date & time.
  2. Press & hold the lower right button on the side (SET) until the word TIME appears on the display, then release it.
  3. If SET T1 is showing, then press & release the upper right button on the side (RECALL) to change it to T2 (because we're wanting to set the 2nd Time Zone we'd leave this unchanged if we wanted to set the 1st time zone, T1.)
  4. Press & release the lower right button on the face (START/SPLIT) twice, skipping the seconds. You should see the hours flashing.
  5. Press & release the upper right button on the side (RECALL) repeatedly until you have the hours position set to what you want it to be. If you pass the hour you want, go to the lower left button on the face (STOP/RESET) and press & release it to back up.
  6. Press & release the lower right button on the face (START/SPLIT) three times, skipping minutes and months, so that the date begins flashing. Press the RECALL button until you have the date you want. (You can go backwards by pressing the STOP/RESET.)
  7. When you're done, and you've set everything you want to, press & release the SET button once to tell the watch you're through setting and to lock those settings in.
Nov 23, 2015 | Timex Ironman Watches
I have to set the date everytime I switch it on
On this camera you have a supplemental litte battery that is just beside the AA batteries. If you pull on the little tab that says CR 1220 you will find a battery that looks like a battery watch. Just replace it, go back into your date/time settings and you should be good to go! It worked for me!
Dec 20, 2011 | Canon PowerShot A400 Digital Camera
Hi, I have an nikon coolpix s710...after I set date and time, when I turn off and start again, it ask me if I want to set date and time...please help me to fix this problem because when i start the camera...
1. In Set Up you must select the language you want to use by highlighting it then PRESS OK. If you don't do this then the date/time will not set.
2. When asked to set date and time you must select YES and press OK.
3. After completing each step you must press OK.
4. In the final step you must choose your preferred day/month/year display and then press OK.
If you don't press the OK button at each step the date and time will not set.
Aug 17, 2011 | Nikon COOLPIX S710 Digital Camera
Trying to seth the date on my Timex Indiglo CR1216
Jul 07, 2011 | Timex 40131 Wristwatch
Camera Canon A710 IS started to ask set time date when turned on
When the camera is left without power for an extended period of time, the time and date settings are gone. You need to reset them and when you're finished, click the set/ok button twice.
Feb 25, 2010 | Canon PowerShot A710 IS Digital Camera
CHANGING DATE. SET DATE INCORRECTLY WHEN USING 1ST TIME
I understand that you wish to change the date on your KODAK camera.;
Please go into the menu, camera settings, date and time.
You can also reset the camera: Take the batteries out for longer than 10 sec. reinsert and the camera automatically asks you to set date and time.
Jan 16, 2010 | Kodak EASYSHARE Z1285 Digital Camera
Cet in set up mod to change date
Dec 30, 2009 | Kodak EasyShare C180 Digital Camera
Canon xt menu button will not work. When I turn
I'm pretty sure I heard of those buttons going bad when I was researching used cameras...might have to get it repaired unfortunately...
Saw a few ads on craigslist etc. where person said "camera takes pics fine but menu button stopped working recently". Maybe there's a recall?
Aug 10, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Can't change date or time on my new Pentax K2000
Date/time are set at "first use" or through the tools menu.
Remove the batteries.  Leave the camera overnight, this may be enough to lose the current settings and allow setting new date/time.
Press Menu button.
Press right arrow on the 4-way controller to get the Tools (spanner) highlighted.
Press down arrow to get to date (or time).
Press right arrow
Now set to your preferred format.
If this does not work, try changing another item in the Tools menu.  If that change is not accepted, then it's into the dealer.
Jun 21, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Canon PowerShot SX100 IS Digital Camera Logo
239 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
