Question about Sony Car Audio & Video
The problem is , that every disk is comming out,after, TOCreading
The problem is , that every disk is comming out , after , Toc reading
  • 138 Answers
You cd reader lens could be just dirty. take it in for service.
Posted on Jul 15, 2009
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
Swap Magic Problems
TOC disk error normaly occurs when tool 1 of the set that goes in the small square hole at the front left of the drive bay above the power switch is missing or installed wrong
have a look at this
http://www.mod-chip.com/Lite/Magic_Key_2_PS2_Install_Lite.pdf
Apr 24, 2008 | Sony PlayStation 2 Slimline Console
Window shows NO DISK when there is a disk in the unti
If the CD manually loads correctly, the pickup(laser has gone bad) and no longer has enough power left to read the disc the TOC, (table of contents), showing no disc on the display. If you're interested in a repair, please contact me through my website, audioserviceclinic.com. Thank you.
Nov 16, 2013 | Pioneer Audio Players & Recorders
Toc error 14
So, did you check your SET-UP menus?
Aug 28, 2012 | Audio Players & Recorders
Ive just got a mini disk player and its comeing up toc error,can you help me please
Probably not. There are various reasons that TOC errors occur, some are fixable and others not, but Sharp MD units were really known to suffer from them for multiple reasons all at once. TOC means Table Of Contents; it's an index file on the disc which tells the host machine where everything on the disc is located and the TOC is modified whenever you edit a disc. Sometimes the file gets corrupted, but often the machine itself simply becomes unable to read the disc and as the TOC is the first thing it tries to read then you get a TOC error.
If you're lucky the TOC error is limited to a single minidisc; if this is the case then it's just one faulty disc and although there are ways to perform TOC cloning they usually involve hacking the host machine in various ways which may cause permanent damage. Unless the disc is important, just chuck it away and use a new one. If the fault is with the player then again, just chuck it into the nearest electronic waste recycling bin. Spares are not available, and as it's a Sharp, diagnosis will be difficult and the fault likely to return.
Many MD players are practically worthless these days so they're often available on FreeCycle and Freegle groups: Sony are the preferred choice by far, and are also the most commonly offered brand, but take whatever is on offer without complaint and worry about problems later; after all, they are free.
Mar 03, 2010 | Sharp Audio Players & Recorders
When i inserted my mini disc it said TOC Reading then said Toc Error and C14. What is the problem?
Sounds like you lost power when you were finishing recording a disc. On a home unit it got unplugged before you had the TOC written, or on a battery unit the battery died when it was writing the TOC (table of contents) for the disk.
Jan 01, 2010 | Audio Players & Recorders
TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
Aug 19, 2009 | Sharp MD-MS702 Personal MiniDisc Player
TOC eror
The TOC error is the same error seen on computer disks, TOC is the table of content, this has to be read before the the unit will know the details of tracks etc......
If every disk inserted (not just burned discs) has this error, the laser is faulty or out of alignment. Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 01, 2009 | Kenwood Sirius KDC-MP522 CD Player
Emerson 3 disk CD player - CD spins - message
im not sure what toc read means, my cd player says that im guessing it means its loading, any ways take the d player apart an clean the lens wit a cuetip that should work, or the cds may be to scartched to read
Oct 15, 2008 | Audio Players & Recorders
PS2 Disc does not spin
just because you see read doesn't mean the laser is good.
the laser has to read the toc (table of contents) for it to read the toc it must be at the beginning, it must be at the right depth from lens to cd and the spindle must spin. now if you have to spin the spindle that means it most like is not reaching the beginning of the cd or the spindle motor is bad.
Jan 02, 2008 | Sony PlayStation 2 Slimline Console
Car Audio & Video Logo
49 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
