Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Reformat my external drive to NTFS
My problem is that I can not back-up files larger than 2GB for example a PST that is almost 6GB. It says not enough space when I have 250GB available.
If I reformat my external drive to NTFS, I will first copy files to another drive, but when I reload after reformat will I have issues with the files as they are now NTFS vs FAT32. Are their any risks associated with changing the format?
Thanks in advance.
  • 358 Answers
The only risk associated with file formats is that a drive formatted with FAT32 file system will not see NTFS formatted file system, whereas, a drive formatted with NTFS file system will definitely see FAT32.
To make it clearer, this means that, if on your system, your hard drive which is having the operating system installed on it, is formatted with FAT32 file system, and you bring an external drive, or even a backup drive which is formatted with NTFS file system, and you plug it to your system, the system will detect it but it wont be able to access the full drive capacity, you will just see it in the device manager page that it is connected.
But If it is Vice-Versa, the NTFS formatted drive will detect the FAT32 drive.
Now in your own case, if your system is formatted in NTFS file system and you plug in your external drive which is NTFS formatted also, from what you have said, I suspect that you have some hidden partitions on your harddrive (the 250GB), so when you plug it, try and do this, Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
If you see any other hidden drives there, do the same thing to it.
This should make your External Drive to be detected automatically.
Hope this helps you out.
Posted on Jul 15, 2009
My hitachi xl 1000 will not let me move files to it larger than 4,200,000 kb. I am saving some old videos on my computer and need to be able save large files to my hard drive. Do you know how to change...
I'd be willing to bet that your drive is formatted in FAT32, which has a single-file cap of 4GB. Reformat the drive in NTFS or EXFAT and you should not have any more problems.
Nov 16, 2012 | Hitachi 1TB External USB 2.0 Hard Drive
I'm Windows XP... I can copy many files to the Verbatim. But when I try to copy a 1GB+ file, the copy craps out. I Googled and found some Microsoft problem when copying 1GB+ files to external drives, but...
The usual limit is exactly 2GB, not 1GB.
It's a limitation of the file-system used for the directory of the disk-drive, when formatted according to the 'FAT32' specifications.
So, copy all the files currently on the Verbatim to your disk-drive.
Then, "reformat" the external (not the "internal") disk-drive, using the 'NTFS' file-system. This file-system has a maximum-file-size limitation for one file that is _much_ larger than the capacity of your Verbatim.
Then, copy all the "saved" files back onto the Verbatim.
Finally, copy your "large" files onto the Verbatim.
Sep 30, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Why can't I copy larger files than 4 maybe 5GB to my passport WD? Is there a quick way how I can change this?
Your disk is formatted using FAT32 file system. FAT32 has a maximum single file size of 4GB. Reformat your drive using NTFS file system to enable file saving larger than 4GB.
To reformat the drive:
-insert external drive
- open "My Computer", point your mouse over the drive letter of your external drive, right-click and select "Format". Select NTFS from drop-down menu under "File System".
-click "Start" button
Please note that all data will be deleted so please backup your files before formatting the drive.
Aug 25, 2010 | Western Digital Passport WDXML800UE...
Currently my 500 GB WD External Drive has 353GB as free space. But when I try and add a 6GB file I get the following message "Error Copying File or Folder Cannot copy filename: There is not enough free...
How many directory deep is the file going that you are trying to save? I believe the maximum NTFS file (location + name) of file length can not exceed 256 characters total.
Example: C:\user\documents\file.exe is OK
But: C:\user\documents\folder\folder\folder\folder\folder\this folder name 230 charicters long\file.exe BAD
Feb 05, 2010 | Western Digital My Book Essential Edition...
I have a 16GB Cruzer Flash Drive. When I try to transfer a file that is just under 8GB to the Flash stick, it tells me there isn't enough room....
Check the propeties of the Flash drive. It it most probably formatted using the FAT32 file system, which does not allow files larger than 2GB.
There is a way to format a flash drive using NTFS file system, but you will lose some capacity of the drive, and transfer speed will be a bit slower, gaining in return a possibility to transfer larger files.
Go to the following webpage for instructions:
http://www.online-tech-tips.com/computer-tips/format-usb-ntfs/
Dec 03, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My new 500 G external hard drive seems to limit the file size under 5 G. Is there somewhere I can reset this to larger file size?
A disk may be formatted using different file systems. The ones used by Windows PCs are FAT32 (an extension of the old MS-DOS FAT) and the newer NTFS.
If the drive is formatted as FAT32, the maximum file size is 4.294 million bytes (some systems report this as 4.294 GB; it is actually 4 GB minus one byte).
If this is the case (Start -> Run Command -> DISKMGMT.MSC and look for your external drive, it will say something like 489 GB NTFS or 489 GB FAT32), my suggestion is to back it up somewhere else and reformat it as NTFS. There also are utilities to convert FAT32 into NTFS, but if anything goes wrong during the conversion, you can say goodbye to all your data.
Note that you won't be able to access a NTFS formatted external drive except from Windows PCs (and most Linux, usually read only), while FAT32 disks are readable from Mac OS X too.
Nov 03, 2009 | Acomdata HybridDrive E5 Hard Drive
I am trying to add more files to my iomega hard drive and it says "iomega cannot be modified" Why can't I add more files?
Your external hard drive is formatted NTFS. This is a Microsoft proprietary hard drive format which is why Mac does not have a driver to write to it out of the box. You have two options:
1) You can either make sure to buy Western Digital products which all come formatted FAT32 which is writable by Mac's and PC's (There is a 2GB file limitation, a single file can not be larger than 2GB with FAT32)
2) Install a NTFS driver. The NTFS-3g driver is stable and I have been using it since beginning of 2009 with no problems, you can download it here (http://www.ntfs-3g.org)
Oct 21, 2009 | Apple MacBook Mac Notebook
It isn't letting me transfer files that are larger than 5 gigs to my WD external HD. Says not enough space. How do I make it so I can transfer them?
Check to see what file structure the drive is formatted as. It's possible that it's formatted as FAT32 instead of NTFS. If that's the case, backup your data from the drive, reformat, and then you can transfer the data back to the drive.
Jul 31, 2009 | Western Digital My Book Essential Edition...
My MyBook says it has 463BGB free space but doesn't act like it
Hey,
There is a FileSize limit on FAT32 filesystem that doesn't allow files larger than 4GB. make sure the drive is format as NTFS, or if your using a mac, that won't work and you would need to split the file into to parts.
Let me know if you need anything else.
Thanks,
Ekse
Feb 21, 2009 | Western Digital My Book Essential Edition...
My Book 1Tb will not let me put movies on it
I know exactly what your problem is. You are trying to add a file bigger than 4 GB on a fat32 external hard drive. You simply cant put something that big in there without breaking it into smaller bits. You could easily add a bunch of small files just not huge files bigger than 4GB.
Your solution would be to reformat your WD external drive to a ntfs. That can be done as easy as right clicking your external drive through my computer and highlighting "reformat". Good luck and I hope you dont forget this little thing about computers..sometimes when you get a good deal on pc hardware its for a reason :)
this is good for all hard drives including western digital
Nov 28, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
1,071 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
