Samsung 7 Galaxy Tab 4 8GB White Logo
c
carressa wood Posted on Jan 14, 2016
How do i connect my tablet to my tv using a usb cord
Namit Jain
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Feb 09, 2016
Namit Jain
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
487
Points
9
You'll need a micro usb to HDMI adapter. But not all tablets support it.
1helpful
Connecting tablet to tv
Use a usb to usb cable. Find an application fron application stote to send tablet screen picturr to tv. Install it. Run it
In case that you have a ei fi tv. Then srsrch for those application that broacast screen to tv. Air connected, stream tv mirroring, play to tv, etc.
Do i need other cord to connect keyboard
keyboard connected to a tablet ? there are only two ways I know of doing this , one is if tablet has a usb port and you have a usb keyboard (keyboard gets its power from same port) or second way is to use Bluetooth keyboard (if tablet has blutooth) keyboard gets its power from internal batterys and has a power switch then
Can I connect my fire hd 10 to my tv using a cable.
It seems as if it is possible to connect your Fire HD 10 to a TV via a HDMI cable. In order to do this you will either need:
  • Amazon HDMI adapter for fire tablets
  • Micro HDMI/ USB to HDMI cable
Here is a helpful article with ways to connect to a TV and links to the types of adapters on amazon.
How to Connect Kindle Fire to TV
Amazon com Amazon HDMI Adapter for Fire Tablets 4th Generation Kindle Store
Amazon com AmazonBasics High Speed Micro HDMI to HDMI Cable 3 Feet Latest...
1helpful
My irulu USB is broke so my husband bought a HDMI cord but still won't charge. What can be wrong??
HDMI won't charge a tablet as it is used for output to a display like tv it is not an input. port. USB is a way of charging as it has dc voltage on it. that charges devices.
2helpful
How would I connect my acer a1 830 to to my tv to watch showbox ... I was told i could use a micro usb to HDMI adapter to do this and cannot figure it out....
No, the A1-830 doesn't support MHL (micro-USB to HDMI). So the micro-USB to HDMI adapter will not work. The tablet's USB port will only support connecting to the charger or a PC's USB port. Here's a list of known MHL devices: http://www.mhlconsortium.org/devices.aspx . The previous model (A1-810) had a micro-HDMI port that could connect to a TV's HDMI port with the appropriate cable. You might be able to use the AllCast app and a Roku or FireTV box. You will need to upgrade to the Premium version for any files longer than 5 minutes.
The other way to mirror content from the Iconia A1-830 would be to transfer it to your computer. Then send the file to the TV via Plex or SmartShare depending on the file and your TV. If you can upgrade the tablet to Android 4.4.2 or higher, then a ChromeCast will let you mirror content directly from the Iconia A1-830. This will require steps that can make the tablet unusable (research rooting an Android device).
I wish that I had better news for you. Unfortunately, even if you have a TV with a USB port, it probably will not access the files on the tablet. (Many only support FAT32 or NTSC file systems.)
I hooked my tablet up to my tv via usb cord and cant figure out why i cant watch my netflix on the tv
On the TV you need to select the port for the USB. You should have a source select button on your remote for this. If not it is in our video menu. Second, you have to make sure there is not a setting on our tablet that needs to be turned on for sharing.
8helpful
How do i connect my tablet to the tv
Visit my blog lol
http://pcgadgetdeni.blogspot.com/2013/02/how-to-watch-videos-from-your.html
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
