Question about Zanussi ZWF1430W Front Load Washer
ZWF1430s not Zwf1430w as previously stated have now had carbon brushes replaced by washer repair man but still have same problem starts cycle fills with water but does not agigitate or spin.
    Problem Solver:
  • 6 Answers
Motor fault, belt broken or pcb..........moe likely the armature in the motor faulty
Posted on Jul 15, 2009
Whirlpool 6th sense wont start cycle
I have the same problem. Look at the previous post, it seems to be the motor brush worn out. I've opened up the machine and checked. The carbon brush remains very little. I am trying to find out a replacement brush
Dec 27, 2013 | Whirlpool AWM6100 Front Load Washer
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
E52 fault code displays on ZWF1430S Zanussi and drum does not turn in wash or spin cycle. Can you advice?
Zanussi 'E52' decodes as 'no signal from the motor tachometer' which ties in with the fact that the drum does not turn. Sorry but it looks like an engineer call-out, either for the motor or the control ;-0(
Good luck,
John C
Mar 25, 2011 | Zanussi ZWF1430W Front Load Washer
Whirlpool washer model #lsr5132hq1- drum turns but agitator doesnt on second spin cycle until you give it a spin by hand. ok on first spin cycle
May be the motor carbon brushes are worn. This is usually a cheap repair 10 or 20 pounds if u can do it yourself , but disconnect from mains , take out motor , remove , replace carbon brushes, ( some motors don't have them) you can understand what I mean, my advice is estimate from local dealer but dont get conned with new motor ( I think its carbon brushes only) .
pete
Nov 10, 2010 | Whirlpool Washing Machines
ERROR CODE E50 SHOWING AFTER POWER SUPPLY INTERUPTION
It was probably your washer that tripped the electric . e50 relates to the motor check the carbon brushes they will be worn out. hopefully with new brushes you will be back in action. the programme wont start with a fault on the motor
Jul 24, 2010 | Zanussi ZWF1430W Front Load Washer
Can you tell me what code E50 is please?
Yes E50 indicates that there is a fault on the main motor.This hopefully is worn carbon brushes which can be replaced at reasonable cost.If the main motor is faulty and this machine is out of the 5year parts warranty (2004 from mod. no.)It would be costly so check the brushes first.
Hope this helps.
Good Luck.
Apr 22, 2010 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf1430s error codes - E40 / E41 & ELE
hi
ele means the pcb is in factory settings . all you need to do is turn back off the on again then will be back to normal use. but e41 usally means the door lock has failed. does it click alot when you start it up and not do anything? if so this will be the lock
regards
Mar 19, 2009 | Zanussi ZWF1430W Front Load Washer
Drum not turning
My problem is the same as colins my hotpoint wm63 is starting okay i.e. water fills up but drum is not turning. I can hear it clicking through the cycle but drum doing nothing. i to have just put in new carbon brushes but still no joy please help
steve
Apr 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Zanussi ZWF1430W Front Load Washer Logo
388 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
