Question about Intel Motherboard
Motherboard problem? My computer keeps on hanging and sometimes shuts down abruptly.this happens especially when a attempt to use it for culculations or sound editing.The make is Astrock 4145gx-pe with pin processor 2.4ghz.Should i buy a new motherboard as my Friends suggests or is ther anybody out there who can help.G.Kimathi
  • Bruce Hathcock May 11, 2010
    Well all of these sound good but I will add a simple one buy a can of compressed air and clean out the power supply fan and the cpu fan and add a couple of case fans to help with heat, I had problems with some of my older asrock boards and bought new fans for the cpu a cobalt turbo cold fan, when I would run 7 dvds and would edit audio and video it would heat up and go off took a 110 fan and put it it a couple of feet away from the box and found out it was a heat problem, most techs tell you that's a no no but it worked for me and did not cost anything to find out.
  • 167 Answers
Hi- i would say that it is a heat issue. check the temps of the cpu-also check some of the bios settings, my asrock board has some bios settings that are for safe overclocking-like bumping up voltage. set these to default.-one is called vccm, then vlink,then over vcore. vccm set-to high- vlink set to normal- over vcore -disable. but do check the cpu and if you have some heat sink compound- take the heatsink off and reinstall it with the new compound. make sure you clean the old compound off. if you need more help-reply good luck!
Posted on Jul 16, 2009
  • 1 more comment
  • glenn hoffman
    glenn hoffman Jul 16, 2009
    http://speedfan.en.softonic.com/ here you go-speedfan download. be well!
  • glenn hoffman
    i should have also said could just be an operating system problem, like chipset drivers-ect. try speedfan first! good luck! let us know how it goes..
  • glenn hoffman
    glenn hoffman Jul 25, 2009
    other thoughts- redo windows and all other software you have. after checking the settings i mentioned, a clean windows install would be a good thing.but first try this speedfan and see if it is a heat issue. http://speedfan.en.softonic.com/
  • Intel Master
  • 19,396 Answers
It is not necessarily motherboard, this can be an overheating problem.
When the cpu goes under stress because of heavier load, like when you do calculations, or start more complex processes, it produces more heat.
If the Heathsink cooling is insuficient, or if the CPU is defective, this may cause temperature raising over the critical limit and computer to shut down.
CPU critical temperatures may vary between 60 and one hundred centigrads, depending on the processor type.
Here a diagram: CPU maximum temperatures.
You can monitor CPU temperature using software like SpeedFan.
If the problem is CPU overheating , replace the CPU fan first, and ensure that the fan is well in contact with cooling paste on top of CPU surface.
Regards.
Posted on Jul 15, 2009
In our pc cant insatall audio software of realtek. it shows like this at the time of installing "install realtek hd audio driver failure"
Posted on Jul 25, 2009
  • 217 Answers
no need to buy new mother board..
u try to reinstall the os.. it will do for u..
  • 198 Answers
Try other routes first.
See if you can do a System Restore, try and remember the point when this started.
Re-Install Windows and see if this helps with issues, back up your files first.
If it persists after a fresh install, then yeah, replace the motherboard.
My computer shuts down abruptly even before loading windows.all the funs are running normally thus i overule the problem of overheating.
you could run a memory test "mamtest86", you could start removing unnecesarry pherephials and cards (who needs a telephone momem anymore?) and disabling devices in your bios, and you could test your power supply.
May 21, 2010 | Asrock P4I45GV R5 Motherboard
Speedometer Quits Working on Cruise Control
Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Impala instrument cluster repair
Nov 30, 2009 | 2005 Chevrolet Impala
Abrupt shutdown of Lenovo 3000 Y410
motherboard thermal section problem
joe
Nov 03, 2009 | Lenovo 3000 Y410 Notebook
Computer keeps shutting off without warning
If the PC doesnt show the shutting down dialogue, then hardware proble if it does then its a software problem. Try to replace the powersupply, abnormal voltage sometimes causes this problem, memory and motherboard errors can cause your PC hangs up or blue screen but will not shut off.
Oct 21, 2009 | Computers & Internet
Computer hangs up on shutting down screen
Ok.....
1. Make sure ALL user accounts are logged off!!!
2. UPDATE ALL DRIVERS
3. Check to see how many Programs are running while attempting to Shutdown the PC..(the more programs it tries to close, the longer it can take...(ESPECIALLY WITH LOW AMOUNT OF RAM/SLOWER RAM)
Mar 22, 2009 | Toshiba Satellite Laptop with AMD Athlon...
Compputer shuts down abruptly
If you have recently fitted new hardware. Take it out.
If not, buy a power surge protector from your local pc store
Jan 30, 2009 | 2005 Mercury Villager
A21m keeps shutting down
Have you checked the ventilation area of the processor if it is blocked by dirt? It causes heat to processor, when it reaches a certain hot temperature, it automatically turns off to avoid further damage. Have it opened and be cleaned by a computer tech
Jan 24, 2008 | IBM ThinkPad A21m 2628 Notebook
Intel Motherboard Logo
246 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
