Question about GE Washing Machines
Leaking water water is leaking and is not spinning when washing
    Scholar:
  • 78 Answers
Thank u for bringing your probl to our notice.
well, for leaking from the washing machine is mostly a directly result of wear n tear of drain gate rubber washer, try replacing the washer with new one, will solve your problem, or else u can give it to nearest serive center, u'll b delt within an hour.
not a major problem to worry sir.
if my solution has helped u, then plz give a vote as a feedback. thank u.
Posted on Jul 15, 2009
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Nov 23, 2017 | Washing Machines
Hi my MW512 Fisher Paykel doesn't spin properly washing still comes out with water still on
could be something stopping the pump from working,, the water control is leaking allowing water to come in while spinning, outlet hose from pump blocked/kinked
and not reaching full spinning speed ( overloaded wash)
May 06, 2016 | Fisher Washing Machines
Defy dishwasher leaks water only at the end after spin cycle
please confirm if you are referring to a dishwasher or washing machine. Usually the spin cycle applies to washing machine. Check where the water is leaking from. Most likely the drain pump hose is cracked. Need the model number of washing machine to make further suggestions.
Dec 29, 2012 | Dishwashers
Washing machine leaks during spin and drain cycle
If the leak is still present after you replace the hoses , you may need to get a new water pump ( cheap part ) it is probably leaking , it removes the dirty water from the washer during spin and rinse cycle . hope this helps
Jun 28, 2012 | Washing Machines
My whirlpool wtw5500sq0 leaks water when washing
There can be many causes for this leak, and where it leaks helps diagnose what to fix. Most commonly the water pump leaks from its seal and bushing over time since it spins whenever the motor is engaged. The reason it never spins water out until the spin cycle engages is because it is turning in the opposite direction as flow to prevent water running out as you wash, You way also have a separation of the washtubs water ring, or a crack near the top, since the leak only happens during wash time.
Mar 18, 2010 | Washing Machines
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
Maytag A512 Leaks out airgap when draining/spinning out
Check pump. I would say it is the most likely cause for the water leak, especially if itdoes it while filling and on spin as the pump holds some residual water in it . That is normal.
Feb 10, 2008 | Washing Machines
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
