Question about Canon NP 6551 Black and White Copier
Codes e004 - Canon NP 6551 Black and White Copier
  • Canon Master
  • 1,297 Answers
The E002 & E004 fuser unit malfunction code.Please check and clean the heater lamps,fuser thermistors & thermofuses.Check or change the SSR.
Posted on Aug 02, 2009
We are facing error code e004 Scanners in Konica Minolta c224, please help us if you have any solution.
Try to upgrade the firmware of the mashine to c224e. Remember to use USB device max 2gb volume
Jan 11, 2015 | Konica Minolta Office Equipment & Supplies
Tip
How to resolve Cannon ir400 Error e004
<span>Hi,<br /><br />For error code E004-001 or E004-002<br /><br />Cause:<br />The SSR has a short circuit.<br />&bull; The SSR has an error.<br />&bull; The DC controller PCB has a fault.<br />The heater relay has an error.<br />&bull; The heater relay has an error.<br />&bull; The DC controller PCB has a fault.<br /><br />Description:<br />&bull; The fixing heater remains<br />on.<br />&bull; The fixing temperature has<br />increased abnormally.<br />The heater relay remains on.<br /><br />FIRST TRY TO CLEAR ERROR:<br />Resetting Errors<br />1. The following error codes cannot be reset by merely turning off and then on the main power.<br />They require resetting in service mode:<br />E000, E001, E002, E003, E004, E032, E717<br />1) Start service mode, and select COPIER&gt;FUNCTION&gt;CLEAR&gt;ERR.<br />2) Press the OK key.<br />3) Turn off and then on the main power.<br />2. Error codes other than the above may be reset by turning off and then on the main power.<br />n Detail Code<br />Some error codes offer detail codes, which may be checked in service mode:<br />COPIER&gt;DISPLAY&gt;ERR (3rd block from the right)<br /><br />SERVICE MODE: <br />1) Press the asterisk key ' * ' on the control panel.<br />2) Press '2' and '8' on the keypad at the same time.<br />3) Press the asterisk key ' * ' on the control panel.<br /><br /><br />If these doesnt helps, you need to call service to locate the fault, which is probably bad thermistor.<br /><br />Hope that helps!<br /></span>
on Feb 06, 2011 | Cannon i70 Printer
Casio ce6000 error code e004
That means it is having trouble with the memory backup. Don't unplug the machine as it is about to lose all programming and sales data. Has this machine been turned off for a long period of time? When was the battery last replaced?
Jun 25, 2013 | Casio Parts Cash Register PC Desktop
I have a casio se-c300 keeps saying e004 tried holding feed down and turning on says bt init. it doesnt do anything until I press sub total then loads of zeros then back to e004!
That usually means it has not been initialised at the factory. your dealer should have done this before you bought it. Did you get someone to set it up for you? It is waiting for a MAC code
Jun 16, 2013 | Computers & Internet
Canon ir 400 error code e004
The error code E004 deals with the fixing unit. Odds are that you may have one or all of the following parts need to be replaced > the fixing lamps or thermistor or the thermal fuse or the upper fixing roller.... Just for starters... Good Luck
May 05, 2013 | Office Equipment & Supplies
Canon NP 2120 Copier that is giving Error Code E004 on power up. Any solutions?
E004 CODE IS FOR FIXING UNIT TEMPERATURE IS NOT REACHED THE SPECIFIED RANGE. CHECK HEATER LAMP, THERMISTER, THERMOSTAT.
Dec 18, 2009 | Office Equipment & Supplies
This err number whit ist
hello there here is some information that may help you solve this problem ok?
best regards michael
  1. Printer Repair And Service Tools: Ir3200 error code e000677-0004 Canon Multi-Pass Fax C855 waste tank reset code ... Canon Error Code, E000, E001,E002,E003,E004,E005. Ir3200 error code e000677-0004 ...indoresetter.blogspot.com/2009/02/ir3200-error-code-e000677-0004.html - 82k - Cached
  2. C3200 Problem Solving at FixYa how do I reset this code? canon ir 3300. 1 Solution. after pressing *28 it come download mode ... e005 an error canon 6330. the quality of four colour is very ...www.fixya.com/tags/c3200 - 89k - Cached
  3. E004 Problem Solving at FixYa along with e001 and e005... HP Pavilion dv2000t PC... Problem Event Name: APPCRASH ... codes with this model np 7161 e004 iwant to know how to get in reset program...www.fixya.com/tags/e004 - 92k - Cached
  4. The Copier Network - Canon 6085 E5 ... what this code means or how to reset it any suggestions? ... E005 is fuser web out. clear web counter. techla. I replaced the web just coundn't reset the code. ...www.thecopiernetwork.com/printthread.cfm?Forum=87&Topic=18014 - Cached
Sep 14, 2009 | Office Equipment & Supplies
E004
A E004 deals with the fuser unit. Have you looked at the Thermister or the thermal fuse or the fixing lamps? I would say that most likely you have a blown or shorted thermister. One of the wires may have come off the pcb.. I you want to see the error code, I believe it is under *6* counters... *4* is for resetting the code
Jul 14, 2009 | Canon NP 6050 Copier
Canon Laser Class 730i Printer/Fax -- Error Code/Alarm E004. How do I clear it?
E004 Fixing Unit Failure.
I would recomend calling repair Tech to resolve this issue....unless you know how to access service mode and perform a Printer Reset operation. Could be complete Fuser Unit failure.
Jun 02, 2009 | Canon 730i Laser Printer
Canon NP 6551 Black and White Copier Logo
154 people viewed this question
old marine
old marine
