Question about Electronics - Others
I have put a scart lead from the av1 socket on the dvd (panasonic) to the cable box vcr connector on the back of the cable v+box and run a hdmi cale from the hdmi socket on the dvd to the hdmi2 socket on the tv. the hdmi1 socket is being used for the cable box. do i need to run any other cables. if not i seem to be unable to get the sound correct and there is a lot of background noise. the picture is fine. the tv is a philips plasma. the audio sockets are being used for the home cinema centre. a diagram would be fantastic but if not possible a fools guide would be ideal.thanks john the home centre has a scart lead from it to the ext2 connection on the tv
    Problem Solver:
  • 8 Answers
Ok, first thing first if you have a cable box and a dvd player both been connected with HDMI cables direclly to the TV you just need to run a cable from the TV were it says audio out into your receiver.
This way everytime you change from Cable box and DVD the audio automaticly will change as well.
Posted on Jul 28, 2009
Transfer to DVD?
If the mini has two scart sockets you can connect a scart lead from scart 2 or av2 into av1 on a dvd recorder then select av1 as the record channel on the dvd and the press play on the mini and record on the dvd.
Mar 13, 2014 | Panasonic AG-DV2000 Mini DV VCR
Tv dvd and sky box
isn't there any manual/ book?
To connect TV to Sky Box VCR, connect the SCART lead from the AV1 socket on the TV to the TV SCART socket on the Sky Box. Connect another SCART lead from the AV2 socket on the TV to the AV1 socket on the DVD player and an RF cable from VCR to the aerial in socket on the TV.
Apr 27, 2013 | Televison & Video
Dvd recordings from tv
You need to connect your incoming signal to the DVD recorder first. So either put your aerial lead (or cable as the case may be), into the aerial input socket at the rear of the DVD. Then you will need to go into the tuning mode on the DVD & tune in your stations. If you are on cable with a scart, then just connect the scart from the cable box to the DVD & select the input source (ie AV1), this will allow you to record
Jan 04, 2010 | GoVideo DV1130 DVD Player/VCR
Where to put scart leads into dvd and video player and panosonic tv
Look at the rear of the TV/VCR/DVD & you will see long black sockets where the Scart cable is connected onto, these are normally indicated as AV1/2 etc. You can then take Scart from DVD to TV on AV1. Then on AV2 take the second scart from VCR to TV or you can take the second scart from the DVD to the VCR & from the VCR to AV2 on the TV.
Nov 29, 2009 | Panasonic CT-32SL14 32" TV
Cannot tune -in my panasonic vcr. it plays tapes but will not record. I have wired together the tv, sky box and vcr in what seems the obvious way (and every alternative) but no joy so far. can you help?
The main aerial goes into the vcr,a fly lead then comes out of the vcr into the tv,a scart lead from av1 on the vcr into the tv.If you want to record from sky and the vcr has two scart sockets then connect a scart lead from the sky into av2 on the vcr,when you record from sky you select av2 on the vcr as your record channel
Sep 24, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Tv & video: Which cables join to where
You need to put the main aerial into the vcr,then a male to female fly lead from the vcr into the tv and then a scart lead from av1 on the vcr into the scart socket on your tv.
Sep 13, 2009 | Televison & Video
Can i transfer my home video vcr tapes onto dvd using my panasonic dvd recorder dmr e30, if so how?
Hi,on your vcr and dvd you should have scart sockets,on the vcr connect a scart lead in the one marked av1,on the dvd connect the other end to the scart to the one marked av2.Now on the dvd select the channel av2 using the input button on the r/control.Now all you have to do is put the vcr on play and the dvd on record.I hope thi helps
Aug 04, 2009 | Panasonic DMR-E30 DVD Recorder
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Connecting a freeview box
Your dvd player should be connected to the TV INPUT under norma conditionsl.What kind of recorder are you using? VCR player ?, Is it also a VCR recorder ( one cannot assume because I happened to own a VHS\vcr PLAYER, not player & recorder)Is Your VCR recorder? Then It must be connected to freeview box with universal scart to RCA converter box.You have "" dvd player in av2, vcr av1"" where? TV? freeview box scart connector ?
You will need scart to RCA converter box for sure.
Aug 08, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Electronics - Others Logo
102 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
