Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Sometimes it doesn't spin
Sometimes the washer works correctly but sometimes it doesn't spin. when this happens, it drains and i can here clicking but it doesn't spin.
    Novelist:
    Champion:
  • 244 Answers
Might have a small blockadge in the pump if he pump doesnt get the water out in time it wont spin due to the water left in the pump or it could be the carbon brushes which are situated in the motor these are plastic with the carbon inside they are eld on by 2screws if these are lower then 8ml they are too low they need replacing
Posted on Nov 17, 2007
GE washer won't spin
Sounds like it needs a new motor. Electric motors can develop bad spots on their coils. What happens is they begin to work intermittently or only when hit. This is the same problem with a cars starter motor. Probably a pretty easy fix, just unplug the power to the washer for safety and pull it out and get a part number off the motor assembly then order up a new motor. If you have a multimeter and are comfortable working around live AC voltage to can see if power is being sent to the motor at the power connector.
Jan 07, 2014 | GE Profile WPRE6100G Top Load Washer
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
Washer Spin Cycle doesn't work - sometimes
Hello T Wright - Based on the symptoms you are describing, it sounds like more than likely the unit is sensing an out of balance load, which could be too light or to heavy of a load, and the unit will not advance to high speed spin. However, often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 13, 2013 | Frigidaire GLTF2940ES Front Load Washer
Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
May 07, 2012 | Washing Machines
Washing machine isnt' draining nor spinning.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
May 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Sears Kenmore washer that sometimes does not spin in the spin cycle and sometimes it does. The timer progresses to stop, but clothes are still dripping wet. Resetting timer from spin usually...
The transmission in this machine is worn and is not shifting correctly. Understand that after the aggitate cycle, this machine should go into drain cycle without spinning and it should drain for about 1 minute. Then it should kick into spin cycle after it has emptied all the water. What is happening is it is (like skipping) the drain cycle and going directly into spin with water still in it,,, so the spin is slow as it is trying to empty and spin at the same time,,, thus the clothes do not spin out correctly,,, when you reset the spin, you actually spin all the water out the second time around.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Washer spins and drains sometimes but not others
HI,. this is the result of a defective timer mechanism. by replacing this damaged timer, you will correct this problem you are experiencing.
Mar 15, 2009 | Admiral AW22 Top Load Washer
Kenmore 22062 will not cycle correctly
Problem fixed. I took apart the bottom of the washer to access the pump, and found that there was underwire from bras stuck in the discharge tube blocking the water from exiting the washer and that was causing the cycle problem. I guess that the washer knew that there was too much water in the tub and kept trying to expel it.
Nov 14, 2008 | Kenmore 22062 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
102 people viewed this question
Dan Webster
Dan Webster
Sal De
