Hotpoint WF645 error message: test
Hotpoint WF645 error message 'test', lights go on one by one, but it doesn't fill with water, and it spins for a couple of minutes - without actually doing the wash cycle. Kind of like it's doing a test run.Tried switching off, leaving for awhile, reloading.Has been working fine until now.Thank you!
    Problem Solver:
  • 6 Answers
Press start once then press again then hold on/off and cancel for a few seconds should now turn test off should be ok now
Posted on Oct 17, 2009
Have your washer door open so the machine cannot start a cycle, turn the machine on;-
press start
press start again
press on/off button & start together for a few seconds
display shows:- doff
it is now cleared and will work
Posted on Nov 20, 2011
My wt640 hotpoint washing machine wont spin and says f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also check the drain pipe 2 so that it can drain out. if you have checked for blockages and can not find any reset machine by switching off at plug for 5 mins then back on and try again hope this helps.
Sep 28, 2010 | Hotpoint WF645 Front Load Washer
My Hotpoint WF645 washes ok but is very noisy, especially during the final spin. Any suggestions why this might be?
sounds like it could be a bearing going out, or simply might be something stuck around the drum
Aug 13, 2010 | Hotpoint WF645 Front Load Washer
My Hotpoint machine has filled with water and won't empty error F-05 FLASHING before that all lights were flashing ??
Error F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Jan 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT761 washing machine - Error code F-10 The machine is filling with water, then signalling F-10, then pumping the water out. So the fill solenoid and the pump are working OK. If I set the machine...
Thats strange, F10 means no cold fill.
Ok back to basics, you can check the pressure switch by taking off the tube and gently blowing into it and I mean gently, you should hear a click if its ok - make sure the other end is'nt blocked, blow it out with a cycle pump near the drum end
Sep 19, 2009 | Washing Machines
Hotpoint WF645 : Do I Need special tool to clamp
not worked on this model.but hotpoint are usually eaSY. no special tools.but i found it easier to take the front of the machine and work at it that way about 1 hour
Jun 30, 2009 | Hotpoint Aquarius WF000 Front Load Washer
H20 f-08
the machine is sensing a flood you need to get it dryed out remove the front panel and dry out the bottom plate then press pause/cancel twice to clear Fault
May 28, 2008 | Hotpoint WF645 Front Load Washer
I have a hotpoint aquarius wf645 when i put it on a wash cycle it will fill for 1 minute then drain a message comes up F-o7 please help
hold in the start and cancel buttons for 10 seconds, a "test on" message appears, hold in the start and cancel button again for 10 seconds and "test off" message appears, set your wash to whatever mode and it should work...it did for me!
Apr 26, 2008 | Hotpoint Washing Machines
Softner still in the draw
The detergent/softner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next step !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test with a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Aug 03, 2007 | Hotpoint WF645 Front Load Washer
Hotpoint acquiarius WF645
To exit test mode, press start, display goes wild) press start again (display settles down) Then press on/off button and start buttons to gether and hold for a few seconds, machine will now read D;end, or similar, will now work okay
Jul 07, 2007 | Hotpoint WF645 Front Load Washer
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
