Question about Daewoo DSA-122L Air Conditioner
Daewoo split system model DSB-242lhg. Wont work on heat green light is on but no hot air
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Is the unit in heating mode? If so, are the filters clean? Have the system repaired if you cannot fix the problem.
Mat
Posted on Jul 17, 2009
Why does my sanyo model KHS2472 has a red light blinking in heat mode and a green in cooling mode, does not work in either mode makes a gurgling sound when it tries to run?
The red light indicates it's either heating or in defrost mode
Check the outdoor unit if the compressor is running - the large pipe on the outdoor unit should be hot on heating or cool to touch on cooling
When in heating mode - the indoor fan will not start until the indoor coil is warm enough
If the reversing valve that changes from heating to cooling is faulty then you may encounter the same symptoms too
Probably need a Refrig Tech to have a look at it?
Good luck
Jan 07, 2016 | Sanyo 24KS72 Split System Air Conditioner
Hi, I have a Daewoo air conditioner split (model dsb-070L/dsb-091L/dsb-070LH/dsb-091LH, I'm not sure about the exact model number). The remote is not working anymore, and I don't know why;...
Hi Josematamoro
Did you find a solution to your problem. I have the same problem and not sure what to do. I have contacted a airconditioning maintenance person who said he would try and look for the part to fix it.
Cheryl
Jul 31, 2011 | Heating & Cooling
Hi i have a Daewoo DSB 180LH air conditioner but the previous tenants have lost the remote control, what can i do?
Hi Cladia,
I had exactly the same problem! Fixed it by buying a Universal All In One Air Conditioner Remote. Tried a couple which didn't work, but finally found one which did - the Chunghop K-1028E. I purchased it online for $20 inc delivery to Australia.
Good Luck!
Regards,
Will.
Feb 28, 2011 | Daewoo DWA-146R Air Conditioner
Fan doesnt work on heat cool ok
Often the fan will cycle on and off on the heat mode. A cold air prevention mode is often built into modern Ac units whereby the indoor fan wont turn on until the internal system pressure is up to a certain point and heat is available to pump into the room. If the system cant come up to pressure or temperature then possibly the system is low on gas. Place your hand on the large pipe leaving the outdoor unit, it should be HOT when the system is on heating mode and running. If not Hot, then it is low on gas.
Feb 24, 2011 | Pace 18HPEWHEC Split System Air...
Hi, we are working on a Daewoo Split AC, model# DSB-180LHT nad we suspect the receiver p.c Board is processing the commands, as we live in Australia, i am having difficulties in locating a spare parts...
Hi, The Company in the first link below is supposed to be the aftermarket support point for Daewoo. Try here first: http://spares.alliedappliance.com.au/part_enquiry.php
The try this one.
http://spares.bigwarehouse.com.au/price_and_availability.php
Since you did not state any part numbers I am helpless to help you find a replacement. FYI most board failures that I have experienced were condensation / corroson/ water caused. The electrical runs on the boards end up shorting and then take out the PCB transformer and fuse if there is one installed.
Let me now if neither of these companies were not able to help you. I will search again via Daewoo corporate if I need to.
Thanks for choosing FixYa,
Kelly
Nov 10, 2010 | Daewoo DWC-121R Air Conditioner
LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Jun 05, 2007 | LG LSC121PMA Split System Air Conditioner
Daewoo DSA-122L Air Conditioner Logo
474 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
