that shouldnt be hard to fix. to fix that, press the forward button then hold it. it should take you to a H.SET setting with the word SUB flashing. use forward to move the small arrow. move the small speed arrow to 50, then press MODE. the arrow should be on 12:00. if its not, use the forward and reverse buttons to adjust it to 12:00. you can hold any one of them to speed up arrow process. when your arrows are on 12, press the adjust button and then arrows should display the correct time
Hand home positioning normally has nothing to do with time setting.
Just set your local time and date and then you can do the hand home positioning procedure.This will not affect the time setting.If hands,after a while,do not show correctly,this means that the watch is under severe magnetic field, after severe shock or finally watch malfunction.
You must know that on this type of watches analog time follows digital time.
"H-SET" is the "0" hands position.To do this right,go to manual (link below) by using the module nbr found on the back cover (4 digit code in a frame). Timepieces Watches Manuals CASIO
First set your local time, date and year and then run the "home positioning" (H-SET) procedure following manual instructions.If no any other problem exists, normally hands will "follow" digital time when watch is set back to time mode.
Analog time follows digital time.Correctly set your local time and analog time will come up correctly as well.If not, try to run the hands alignment procedure (H-SET) following manual instructions.
