Question about Dishwashers
I have a LX40 and need parts list . I have a valve or solinoid that is leaking on upper back of machine
    Problem Solver:
  • 5 Answers
I have an lx 30
i think its called a breaker fill valve
hobart sells a rebuild kit thats pretty easy
1str unscrew 2 screws that hold cap on and save
with pair of plyers or channel locks unscrew top where 2 screws were screwed into,counterclockwise,
should be a plastic plunger, with rubber seal, rermove and replace with new one from kit, use grease to grease shaft
re enstal.
make sure you have kit before you attempt this.
if you have hard water deposits, clean those areas best you can,on top nut, also if your lx has a booster heater, hard water will cause havic and expensive repairs, a water softner from the yellow pages , will be your lx s best friend, and their not expensive
Posted on Jul 16, 2009
  • 35 Answers
Go to sears website http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001 and that will give you a parts list
Posted on Jul 15, 2009
I have a GW512. The cold water is only trickling into the machine. The hot works fine. I have checked and switched hoses and cleaned them etc. Still only trickles in to the machine. Would it be the inlet...
Hi dan, in all probability it is your inlet solinoid valve, due to high sediment build up in the main water supply can cause the inner diaphragm of the inlet solinoid valve to clog up and stick. you can pick up a new inlet valve anywhere from $25-$60 depending on the appliance spare parts outlet. If you produce your model number with the name of the machine to the spareparts store they will easily be able assist in your matter, even better supplying the spareparts store with the inlet solinoid from the machine, thumbs up if this helps thanks.
May 02, 2011 | Fisher Paykel EcoSmart GWL15
Cold water won't flow fast. Hot water only is fine warm water is slow and cold water almost nothing. Cleaned filter etc Thank you
Hello there and thank you for choosing fixya
The best way is to explain this is like this the washing machines water inlet valve has a solinoid for the hot and a solinoid for the cold and when one of these start to fail the will slowly close untill the solinoid will no longer allow the valve to open so this is why your water pressure is getting low going into the machine for the cold side ok?
So what you are going to have to do is to replace the faulty water valve solinoid.
I would really suggest to replace the valve as a whole it ensures that you have a new part.ok?
Hope this helps if yo need any further dissassembly help let me know and i can assist you if needed
Best regards Mike..
Mar 01, 2011 | Washing Machines
Maytag washer does not shut off after filling the tub
normally when this happnes this means that the water inlet valve is leaking by and needs to be changed see what happnes is that there is a solinoid for the cold and 1 for the hotand after time theyse solinoid valves will start to wear out along with the internal parts of the valve this is a very common thing that happnes to washing machines ok so i would first check this valve out and get it replaced then if this still doesent fix the problem than you may have a problem with your water level switch that determines the water level in the machine and senses when it has the proper amount of water in it normally the onluy thing that goes wrong with these is that they tend to stick evey once in a while or they go out all to gether and need to be repaced but this is fairly uncommon (but it does happen) ok ?
Hope this helps you out
Best regards Mike
Feb 28, 2011 | Maytag Washing Machines
MAYTAG WASHER MODEL LAT9206BAE WON'T TURN ON HOT WATER. THE INLET WIRE SCREEN IS CLEAN AND I HAVE HOT WATER AT THAT END OF THE INLET HOSE. I BELIEVE THE ELECTRIC SOLINOID VALVE IS BAD. CAN I REPLACE IT...
Hello there :
Yes you are right this solinoid valve when they fail will fail in the closed positin thus not letting any water into the maching
and yes this is a replaceable part if you can get the back of the machine off and get to the solinoid valve there are 2 or 3 wires that connect it electrically so make sure to mark these wires for identification and get the right part the rest is pretty easy and self explanitory ok?
best regards Michael
Dec 04, 2009 | Maytag Washing Machines
106:533332300 ice maker leaks; replaced
Good day,
Make certain the fill tube is aligned properly and not the problem. As well, make sure the machine and Ice maker are level.
If you installed a new water valve, and there was no change, then yes the IceMaker is probably defective.
Don't need a model number, just take the ice maker in to any appliance parts house. They will match it up.
You don't normally have to go to Sears. Take the model number of the machine with you if you like.
Dec 02, 2009 | Refrigerators
Hobart lx40 Dishwasher stopped working
Look behind the dishwasher and you will see a cover on the right side,remove it.You may see a transformer with a fuse,check the fuse with a meter if you know how.Open the door look up to the right and left,you should see 2 phillip head screws,remove.Pull the top drawer with the display towards you.If you get this far let me know.
Apr 07, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
The solenoid on the water inlet valve leaks... need illustrated parts list so I can order proper parts assembly
you have the info rite / it is called the water inlet solinoid valve. this along with the mod. ser. # is all you nead to order the replacement valve. hope i was a help
Oct 20, 2008 | Refrigerators
Dishwashers Logo
148 people viewed this question
Top Dishwashers Experts
