The top of my wallpaper sort of hides my icons.
To change the wallpaper on your Android phone, follow the steps below:
1.Tap and hold on the "Home screen" to open the "Add to Home" menu.
2.Select "Wallpapers" and choose the type of wallpaper you want to implement. Three options may be available: Gallery, Live wallpapers, and Wallpapers.
Note: Live Wallpaper may not be an option on some phones. This is due to the limitations of the hardware of the smart phone itself.
Gallery allows you to set one of your own pictures as wallpaper. Tap "Gallery" and select your preferred picture. You can crop the part of the picture you want to use as wallpaper. Then, tap "Save" to set the picture as your background.
Live Wallpapers provides you with a set of animated backgrounds. Tap "Live Wallpapers" and select the live wallpaper you wish to use. Next, tap "Set wallpaper" to set the live wallpaper as your background.
Wallpapers are a collection of pre-installed wallpapers. Tap "Wallpapers" and select the one you prefer. Next, tap "Set wallpaper" to set the picture as your background.
GuruAid.com
I found it, from another web site. SmartUSB.net.
It explains step by step, how to change
font color in a flash drive.
Change font color in your flash drive
http://www.smartusb.net/p/change-font-color-of-your-flash-drive.html
Show your colors to your brother.
Change your flash
drive icon
http://www.smartusb.net/p/change-flash-drive-icon.html
Insert symbols to your flash drive label
http://www.smartusb.net/p/insert-symbols-to-flash-drive-label.html
Hide a file or folder in your flash drive
http://www.smartusb.net/p/hide-file-or-folder-in-flash-drive.html
Add wallpaper to your flash drive background
http://www.smartusb.net/p/add-wallpaper-to-flash-drive-background.html
First you need to create a desktop.ini file in your flash
drive.
Open Notepad and click Save as.
Then set file name to desktop.ini and change Save as type to
All files.
Click Save as.
Place your wallpaper in the flash drive. It should be a
".jpg" file
Open desktop.ini file from your flash drive. Copy and paste
below code to it.
Last line of the code, you can see
"IconArea_Image=wallpaper.jpg". Replace "wallpaper.jpg" with your wallpaper
name.
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
Save your file. Unplugged the flash drive from PC and plug
it again. That's it.
If you need more information
Visit SmartUSB.net
Change your flash
drive icon
There is a method to do it. But not simple. But following few steps you can do it.
Visit SmartUSB.net.
It explains step by step, how to insert
symbols to flash drive label.
I think you will also like these things,
Change your flash drive icon
The easiest method is change file to a hidden file.
Right click on the file - properties - tick on hidden
There is an advanced method, change file to a hidden file
and as well as system file using MS-Dos.
I refer you to SmartUSB.net. It is a good source for flash
drive users.
Change your flash
drive icon
Change the icon of a flash drive or any kind of removable
disk which use to store data, is very easy.
Just try this,
1.
Open Notepad and copy and paste below 2 lines to
it.
[autorun]
Icon=logo.ico
2.
Save it as
autorun.inf to your flash drive
Before to click Save as... change Save as type to All Files
3.
Then copy and paste your Icon file to flash
drive
4.
Rename it to logo.ico
5.
Remove your flash drive from the PC and plug
again
You will see your flash drive with a custom icon
For more and clear information visit
