Question about Lexmark P4350 All-In-One InkJet Printer
Paper jam message still being displayed even after clearing it
I press resume and the paper was removed , message is still displayed I have ristart the both computer and and printer but still the same problem
    Sergeant:
  • 259 Answers
Dear papar is cut in the printer check farcet after and my be possibal remove the carteg and reinstall
Posted on Jul 15, 2009
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
    What this light sequence means that the printer has a paper jam.
    When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
    How to clear Paper Jam
    Press Continue button twice quickly to see the secondary error code.
    To get the secondary error codes
    When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
    When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
    Press and release Continue button twice quickly to display the secondary error code light sequence.
    Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
    We recommend that you clear the entire paper path when a paper jam occurs.
    To clear a paper jam:
    1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
    2 Open the front cover and remove the print cartridge assembly.
    NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
    3 Remove any jams in the area behind the print cartridge assembly.
    4 Lift the flap at the front of the printer and remove any jams beneath the flap.
    5 Open the rear exit and remove any jams.
    6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
    NOTE: The printer reprints the pages that caused the paper jam.
    Jun 30, 2011 | Lexmark E232 Laser Printer
    Says paper jam but no paper in machine but still cannot clear error message to continue printing
    if the paper is jammed, remove it first. then press the "OK" button to resume the printing session..
    May 26, 2011 | Epson Office Equipment & Supplies
    My printer says there is a paper jam, yet I removed the paper jam and pressed resume. How can I fix this?
    Try power-cycling the printer: Unplug the printer, wait 10 seconds, then plug it back in. It should clear the paper jam error message. Hope this helps!
    Mar 12, 2011 | Canon Pixma iP6000D InkJet Photo Printer
    I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
    If paper is jammed, a Paper jam message will appear on the control panel display.
    Follow these steps to clear the jam:
    1. Gently pull any jammed paper out of the output tray or sheet feeder.
    2. If the paper is stuck inside, turn off the Epson Stylus CX.
    3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
      alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
    If paper jams inside the Automatic Document Feeder, clear the jam as follows:
    1. Open the Automatic Document Feeder cover and remove any jammed paper.
    2. If necessary, lift the document cover and remove any paper that has jammed inside.
    3. Press OK to clear any messages on the display screen.
    Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
    When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
    Jun 23, 2009 | Epson LQ-2090 Matrix Printer
    5110 ERROR ON PIXMA PRO 9000
    Solution: Press ON/OFF switch to reset the multifunction device
    Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
    1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
      Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
    2. Wait approximately ten seconds and then press the <ON/OFF> button again.
    3. Wait until the device has completed its cycling process before submitting another job request.
    Solution: Removing paper jams MP800R / MP830 / MP530
    Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
    Clearing paper jams inside the printer
    Clearing credit card-sized or 4" x 6" paper jammed inside the printer
    ASF / Paper Output Slot
    1. Turn off the printer.
    2. Remove paper from the ASF.
    3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
    1. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
      Note: Be careful not to touch the components inside the printer.
    2. Turn on the printer and confirm that the Alarm light is off.
      (If the jammed paper remains in the printer, the paper may be automatically ejected.)
    3. Load paper back into the ASF.
    4. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
    Top
    Paper jams inside the printer
    1. Turn off the printer and disconnect the power cord and USB cable.
    2. Remove the jammed paper slowly using the following procedure.
    3. Open the rear cover to check if the paper is jammed.
    4. Pull out the cassette and check if the paper is jammed inside the cassette area.
    5. Stand the printer with the rear side down, holding the document cover.
    6. Press the tabs together and pull the green cover toward you.
    7. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    8. Close the green cover and place the printer back to a normal position.
    9. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
    10. Load paper back into the ASF or cassette.
    11. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
    Top
    Clearing credit card-sized paper jammed inside the printer
    Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
    If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
    2. Load the same paper type that is jammed inside the printer in portrait orientation.
    3. Power on the printer.
      The paper stock in the ASF will automatically feed the jammed paper from the printer.
    4. To resume printing, load the paper in portrait orientation.
    If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
    2. Open the rear cover.
    3. Fold in four a piece of letter-sized plain paper.
    4. Push in the folded paper until it hits the jammed paper.
    5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
    6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
    7. Pull out the folded paper and close the rear cover.
    8. Power on the printer and confirm that the Alarm light is off.
      The jammed paper should automatically eject.
    9. To resume printing, load the paper in portrait orientation.
    Thanks
    Thiru
    Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Out of Paper. Load Paper Error
    Check
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
    HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
    When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
    Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
    Lexmark P4350 All-In-One InkJet Printer Logo
    59 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
