Garmin Gpsmap 498, External Antenna With Dual Frequency Transom Mount Transducer
Problem for Garmin Gpsmap 498, External Antenna With Dual Frequency...
Can an external antenna be added to Garmin 498
By trotador1 on Jul 15, 2009
My 498 is extremely slow picking up sats. So I'm really interested to know if an external antenna is a possibility for a solution to this problem
Solution #1
posted on Jul 15, 2009
Not Rated)
robotek
Rank: Guru
Rating: 91%, 1193 votes
Hi
Sure you can use an external antenna.
Here it is
It is however really only useful to allow for decent veiw of satelites when the unit is monuted under a the signal shadow of a cabin or below decks. Any GPS will not perform as well if a decent shot of 3 or more satleites is not acheived. I suspect this is what is hampering your device. Using the external antenna mounted to get maximum view of the sky will eliminate any such issues for you.
Please take a moment to rate this solution. heers
regards robotek
Was this helpful?
Yes
No
Popular Solutions for Garmin Gpsmap 498, External
Questions and Unsolved Problems for Garmin Gpsmap 498, External
Do you recommend Garmin Gpsmap 498, External Antenna With Dual Frequency Transom Mount Transducer?
Answer
Answer
Can I use my existing transducer(1000 watt tilted angle low profile Airemar) which is being used on... (More)
Answer
I have Garmin GPSmap 498 and the wiring inside the case has broken due to the RF filter bouncing... (More)
Answer
How can I download a manual for a Garmin Gps map 498. It came with my boat and I would like to... (More)
Answer
Garmin GPSMap 498 with external antenna just began acting up and not picking up any satellites. Is... (More)
Describe your Marine Electronics problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Marine Electronic Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
