Question about Epson TM-T88III Thermal Printer
To print an image using a line thermal printer
I have a Citizen's Line Thermal printer. How can I use the commands: Esc *, GS *, GS /? What I want to do is to download an image on to the printer and print it. I tried with GS * as below
memcpy(tmp, "\x1D" "\x2A\x0F\x22");//width:15(0Fh),height:34(22h)
memcpy(tmp+4,(char *)img, 510);
memcpy(tmp+514, "\x0A",1);
Then send tmp to the printer thru' serial port
But don't know if the image was downloaded successfully
Then I used
strcpy(tmp2, "\x1D" "\x2F"); //GS / ( to print)
strcat(tmp2, "\x01");
And sent the command thru' serial port.
But the image is not printed.
Please help
Thanks,
Mary
2 Suggested Answers
Terry Corrow
  • 10875 Answers
SOURCE: How do I adjust the print width?
replace thermal head
Posted on Jul 12, 2015
Testimonial: "It's a brand new printer. Print is using the appropriate space on the 80mm roll. Printer test prints perfectly. It is just only printing the left half of a receipt or document."
Why is there a line through the print and the batteries are new?
Sounds like one of the thermal contacts is dirty or burnt out. Check with DYMO though. They used to make a cleaning strip that you could run thru Thermal printers to clean off the residue...
Sep 18, 2014 | Dymo LetraTag QX50 Thermal Label Printer
Tip
Avoid buying a new thermal print head!!
Thermal printheads - white lines - - move your image!
Hi People,
I've been a printer engineer for many years now, before that i worked designing label formats and operating thermal transfer printers that produced over 2,500,000 labels daily. During my time operating thermal transfer printers I discovered that sometimes you can have a printhead that blows 1 pixel out, and no more will blow for 3 - 6 months! As sod's - law would have it, the blown pixel would be through a barcode or image, making the printer unuseable until the expensive (usually 300.00 - 1500.00 pounds) printhead has been changed. If you have many vertical white lines through your labels or tags, this might not work. Most makes of Thermal printers that have an LCD display will have margin settings and/ or image movement settings that you can change through the operator panel, you will have to consult your user manual. Simply move the image across the page until the white line caused by the blown printhead is in an unprinted area or sufficiently hidden between characters! In addition to this, if you are using software such as bartender, label matrix or similar, you should be able to edit the label image or label format on your Pc, and manipulate your label format in a matter of seconds, again moving or changing your data fields in a way that hides the offending white line between characters or in an unprinted area. I know this will not always work, but its worth a go as you could extend the life of your print head by upto 6 months.
By M.Schroder
on Apr 06, 2010 | Office Equipment & Supplies
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
It only prints a 6x1"
Sony printers are masterpeices when it comes to digital printing as they produce wonderful quality images.
If you got a new printer and it does the same thing this indicates that the problem iis emanating from the software with which you use in editing the pictures before sending the print command. Somewhere along the line some adjustment must have been made to the software relating to the alignment of the picture on the printer. Once this adjustment is corrected your printer will print fine.
Printers are devices which prints what command was sent to them and do not have any intelligence to act or edit documents on their own accord.
Hope this solution has been helpful?
Happy new year
Jan 03, 2011 | Sony DPP-FP30 Thermal Photo Printer
I am sending raw data to the printer. Where to find ESC codes for different control ops
This feature allows experienced users to see exactly what data is
coming to the printer. This can be useful in finding software
problems. When you turn on the hex dump function, the printer
prints all commands and other data in hexadecimal format, along
with a guide section to help you find specific commands.
To use the hex dump feature, follow these steps:
1. After you make sure the printer is off, open the cover.
2. Hold down the FEED button while you turn on the printer.
3. Close the cover.
4. Run any software program that sends data to the printer. The
printer prints “Hexadecimal Dump” and then all the codes it
receives in a two-column format. The first column contains the
hexadecimal codes and the second column gives the ASCII
characters that correspond to the codes.
Hexadecimal Dump
1B 21 00 1B 26 02 40 40 . ! . . & . @ @
1B 25 01 1B 63 34 00 1B . % . . c4 . .
41 42 43 44 45 46 47 48 ABCDEFGH
❏ A period (.) is printed for each code that has no ASCII
equivalent.
❏ During the hex dump all commands except DLE EOT and
DLE ENQ are disabled.
5. Open the cover to set the printer off line, so that it will print the
last line.
6. Close the cover and turn off the printer or reset it to turn off the
hex dump mode.
PLEASE CHECK THE LINK TO GET THE ESC CODES:
http://www.mit.edu/~vona/MSim/vona/terminal/VT100_Escape_Codes.html
Hope this helps u ..............
Feb 21, 2010 | Epson TM-T88III Thermal Printer
Prints have a thin white line across all the images printed. Everything else works and prints are ok outside of the thin white line running horizontal across the 5x7 prints.
  • Thermal head — generates heat; prints on paper
  • Platen — a rubber roller that feeds paper
  • Spring — applies pressure to the thermal head, causing it to contact the thermo-sensitive paper
  • Controller boards — for controlling the mechanism
I think that you may need to replace your thermal head, A line means there is a place that the head can not head or it cannot recieve data
http://www.youtube.com/watch?v=LWs74J7EfjM
How to matinence it and clean the head
Oct 21, 2009 | Sony UP DR100 Thermal Photo Printer
IBM 4610 TG4 Printer configurations from windows
Hi
you onli need send commands by excel is ASCII CODE its easy
Apr 10, 2008 | IBM 4610 TG4 Thermal Label Printer
Zebra TLP 2844-Z Thermal Label length problem
how are you sending the data to the printer and what type of media are you using? you can set the page hight via the ZPL command ^LL ,the value you send with ^LL is in dot, so if I wanted to set the label hight to 10cm I would send ^LL800. Or if you are printing via a windows driver configure the printer to continues media.
Nov 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Epson TM-T88III Thermal Printer Logo
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
