Front panel connector J16 dell dimension 2350
I cant correct connect front panel connector J16 in motherboard dell dimension 2350.
Please, if you have this information, help me!!!
    Sergeant:
  • 449 Answers
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Posted on Jul 15, 2009
  • thanhdung168 Apr 23, 2011
    HJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJ
    Habit-Forming:
    Scholar:
  • 69 Answers
I needed to connect a USB device to the J16 connector - after checking multiple sites - I disconnected the wires going to the bottom front USB port and replaced them with the wires from my internal USB device. The following is the diagram I used.
Dell Dimension 2350 J16 20 Pin Connector Pinout
Inner Row of Pins 2,4,6................20
Pins closest to Motherboard Edge 1,3,5................19
Pin Name
Pin Number
Description
Wires from USB Device
Pin Name
Pin Number
Description
Data0-
Data - for USB port 0 (Bottom)
White
Detect **
See below **
Data0+
Data + for USB port 0 (Bottom)
Blue
(Possibly Green)
Vcc
+5V for USB ~Both~
Red
Data1-
5
Data - for USB port 1 (top)
6
Unknown
NOTE: Check cable to
these pins - these two might be reversed.
Data1+
7
Data + for USB port 1 (top)
Vcc
8
+5V for USB ~Both~
GND
9
Ground for USB port 0 (Bottom)
Black
Ring *
10
Left Speaker Ring & RS Terminal *
GND
11
Ground for USB port 1 (top)
Tip *
12
Right Speaker Tip & TS Terminal *
Left Audio In *
13
Input for rear Audio (L) *
Detect **
14
Headphone Ground
See below **
Right Audio In *
15
Input for rear Audio (R) *
Keyed
16
No pin
GND
17
Ground
GND
18
Ground
MIC IN
19
Microphone Input (+) (Optional)
20
Unknown
Posted on Dec 29, 2012
  • John Ryder Dec 29, 2012
    I tried copy/paste for the pinout from Word - didn't work. See the embedded .jpg image for the diagram.
    Trying - but FixYa made the .jpg so small it's hard to see...
Has the dell dimension 2350 a usb port for the logitech webcam c310?
Your Dell 2350 has = two front-panel and four back-panel USB 2.0-compliant connectors; but it is so old the web cam will slow:
Jan 11, 2013 | Computers & Internet
I need a setup for ethernet controller dell dimension 2350 please help me
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a
red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled or you could click start control panel administrative tools computer management device manager look for network adapters + expand Ethernet driver
if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
driver or the isp providers installation disk
or you might have to download one
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
if this driver is not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name ethernet driver you might have to try a few times to get it right
hope it helps
May 27, 2012 | Dell Dimension 2350 PC Desktop
What kind is motherbourd
The Dell Dimension 2400 motherboard is proprietary to the Dell Mitac Chassis. It should work in any Dell 2300/2350/2400/4600/4700 case. The main item is the Dell specific power/control panel connection. If you move the board take the control panel with it.
(Personally, it isn't worth the effort)
Jul 05, 2010 | Dell Dimension 2400 PC Desktop
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
Will a dimension 3000 fit into a 2350???? Arel the connectors for front panel usb and acpi the same??
it is the same MITAC chassis so yes I'm pretty confident that the 3000 MB will fit
Dec 08, 2009 | Dell Dimension 3000 PC Desktop
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
Bluford E139765 mainboard power panel connector
Look at the board really close you'll see it at the bottom right corner, SPKR, RSW, PSW, and so on, try one at a time, until you get it
Jul 16, 2009 | Computers & Internet
I need a driver for my dell dimension 2350 for
hi...
the download i have given you here,,,, it is R64645.exe and is described here......
the other link for the Ethernet Driver controller is Here . you can use any one of these. thank you.
I hope everything works out for you, Please rate me!
Jul 03, 2009 | Dell Dimension 2350 PC Desktop
Front Panel help for Dell Dimension 4600
Go to dell site and query for *********** board specs. Then query for the pinouts on the board. Or goodle dell optplex+motherboard+hardwire connections. good luck
Jun 17, 2009 | Dell OptiPlex 170L PC Desktop
Model name BLUFORD. E139765 motherboard. I need J16 pin layout for the power switch, reset switch, etc. Dell is not very helpful with this paticular board for some reason. Thank You for any info. DW
This is what I found after extensive searching,
......................O
.PWR LED- O O
.HDD LED- O O HDD LED+
.................... O O
.................... O O PWR LED+
...PWR SW O O PWR SW
.CON CNT O O CON CNT
Looks pretty lame, huh? I found this on Dell's Community Forum.
I gather, this motherboard was used in the Dell Dimension 2350.
http://support.dell.com/support/edocs/systems/dim2350/techov.htm#1101565
Looking, at what Dell has for the layout of the Dimension 2350 motherboard, there are 20 pins in the J16 header, just like he has crudely shown above. I don't see one missing in the corner, though. Of course, the link above is a crude example from Dell.
This person stated it was for the J24 header on the motherboard. Also stated that it was the Front Panel I/O header. (At least that's what was stated) I believe he was confused with the Control Panel header J24. Hopefully it is for the J16 Front Panel I/O header, as it has the Power On switch, HDD activity LED, Power LED, and so on.
Indications are that the O's represent the pins. There was a statement of taking -> Note, that there is a missing pin in the upper corner, and this orients the connector view, Orients, how you are looking at the connector. Only you will know for sure. I don't have this motherboard in front of me. Dell ISN'T giving ANY info out.
This person had the Bluford E139765 motherboard, in a Dell Dimension 2350.
The statement was also made, that there is a Brown jumper wire that connects the two CON CNT pins together, but didn't know if this jumper is required, as this person is putting this motherboard, into an aftermarket computer case. (?)
Solution?
What I would do.
I would have the power supply plugged in. I would use an LED lamp, with two wire leads attached to it. Leads of about two inches long, or more. (Borrow one out of the Front Panel, or from another parts computer?)
Twist the ends of the lead wires tightly. I would then touch the leads to two pins. Should they be power Out pins, (HDD activity lamp pins. Power LED pins, and so on), the light will light up, and not short out the two pins touched.
(If the LED light doesn't light up, no biggie. It just means the wires need to be reversed. Bear this in mind, when you go to hook the LED's up)
When the two pins for the Power On is found, the computer will turn on.
Judging by the crude diagram the missing pin is on the upper right.
Only you will know for sure, as the J16 header should have a flat place in one corner, where a pin would go. NO pin.
If so, this is what I see.
Processor to the left, PCI slots to the right, J16 header on the right, above the PCI slots. The header goes along the edge of the motherboard, lengthwise.
I'll number the pins like this.
Starting at the Top Left, and going down the Left side.
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
Starting at the Top Right, and going down the Right side.
NO pin, (Would have been Pin 2),
Pins 4, 6, 8, 10, 12, 14, 16, 18, and 20
Pins 3 and 4 are for the Power LED. (Confusion here)
Pins 5 and 6 are for the harddrive activity LED. PIn 6 is for the + wire/
NO connection to Pins 7, 8, 9, and 10
Pins 11 and 12 are for the Power LED.
(Which ones to use? Pins 11 and 12, or Pins 3 and 4? I leave it up to you to test as the computer is on, and see)
NO connection to Pins 13 and 14
Pins 15 and 16 are for the Power On switch.
NO connection to Pins 17 and 18.
Pins 19 and 20 are for that jumper wire he mentioned. I would try it without it. If the computer doesn't come on, or something doesn't work, like the harddrive for example, I would unplug the computer from power, then attach this jumper. Plug in, and see if everything works.
Apr 19, 2009 | Computers & Internet
Computers & Internet Logo
1,812 people viewed this question
David Payne
David Payne
