Question about HP Photosmart 2575 All-In-One InkJet Printer
Viewing scanned item
How do u upload from scanner on vista so you can email it please i'm getting really annoyed now can't upload from scanner to laptop my scanner is a photosmart 2575 all in one i can print from laptop but can't get what i 've scanned
  • 298 Answers
Re: viewing scanned item
Go into HP Director and select save to file
send to email or save as pdf should be an option
It should rescan the file and save as pdf
which you can send as an attachment
you should be able to upload to
kodak imaging if it is available
on vista if exist click on file acquire image
I am assuming you had HP Director on
your software cd for the scanner
Posted on Nov 17, 2007
0 characters
3 Points
How to get scanner to attach to e mail
Operate the scanner from the computer not the printer.
Have you loaded the MP Navigator progam from the cd supplied with the printer?
If not, do that first and then follow the steps below.
Double click MP Navigator icon on desktop.
Choose "custom scan with one click "
Save to pc. (" attach to email "only works on windows mail)
Open saved location and rename.
Write your email & click on insert drop down box
Click on "pictures inline "
Open pictures.
Open MP Navigator folder
Choose scanned item by name
Click on open box
Scan will appear under the text in your email.
May 31, 2014 | Canon PIXMA MP510 All-In-One InkJet...
I really don't have a problem, I would like to know how to scan photos into my computer and them send them in an email. Could you explain it to me so I can understand it. As you can guess, I'm a...
Hey Helen,
This can be hard or easy depending on which softwre your printer/scanner has loaded.
Firstly, install the software that came with your printer scanner.
Once thats done, you should be able to access the scanners functions either through an icon in the taskbar (bottom right corner of your screen) or by pressing the scan button on the printer.
Once the scanner starts up, it should ask if you want to save the scanned image to your PC or, in some cases, email the image.
Save the image into your "my documents" folder so you can find them later and give the file a name that you can easily associate with the image (like my daughter etc)..
Scanning to email will usually start up outlook or outlook express which is no good if you do not use outlook and use a third party email system like hotmail etc.
So, shut down outlook in this case. otherwise, setup your email as you normally would (receivers email address, subject etc)..
If you use hotmail etc, the procedure is about the same..
Once you are ready to attach the image from your scanner, click on "attach" and select file.
In the dialog box that opens, select browse and navigate to your "my documents " folder if it is not already in that folder. Select the file you scanned and named earlier and click on open or attach.
The file will then upload and appear in the list of attachments once uploading is complete.
Click on send and off it goes..
Jan 24, 2011 | HP Printers & Copiers
I have just bought a HP Photosmart plus B210 printer. I have installed it ok and it is wireless connected. everything seems ok for printing but when I try to scan to Paint shop Pro 7 or from Word 2003 it...
Hello Carol,
The first thing you want to do is check to make sure the scanner driver is installed properly and working.
If you are running Windows XP or Vista; go to Start Menu \ Control Panel \ Scanners and Cameras
NOTE: For Vista user you must select "classic view" in control panel to see scanners an cameras.
For Windows 7; go to your Start Menu, in the "search programs and files" section (found below "all programs") type in "scan". You will see a result for View Scanners and Cameras.
Now you should see the HP scanner here. If it is not here then you need to reinstall because the scanner was not installed properly. If the scanner is here, right click on it and select Properties. (For Windows 7 you do not have to right click, you will see Properties at the bottom of the window).
In the properties select "test scanner". If this test fails, the driver is not working and you should uninstall and reinstall the HP.
If this test works then the driver is properly installed. HP should have provided you with some sort of scanning software, try scanning using that. You can also try scanning using Windows Fax and scan (for windows 7), Windows Photo Gallery (Windows Vista) or the Windows Scan wizard (Windows XP).
Nov 07, 2010 | Printers & Copiers
How to scan documents then email them
To scan and send the documents via. e-mail. First of all you must run the setup from the cannon cd (comes with printer), use full installation (recommended option) complete the installation.
If this is already done then :-
1] Put the document that you want to scan in the scanner,
2]Open "control panel" and open "scanners and cameras" folder. (switch to classic view if needed)
3]Switch on the printer (if it's on only then proceed to next step)
4]You will see your scanner icon (if necessary refresh the screen)
5]Open it and click "next"
6] (OPTIONAL) Select scan image type.
7]Click "next".
8]Choose a place to save your image.(default is my pictures)
9]Click "next"
10]and now image scan starts, at last click on finished.
11]Now open your e-mail account, choose "compose mail" fill in the details
12]now select "browse" (for gmail) or select upload file
13]select the address of the image where you saved it (default my pictures)
14]click ok.(you can only upload 1 file at a time)
15]send the mail. !!
16]Thus, you can send image by scanning like as stated above .
Jan 07, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Scanning to email
The all in one solution software you used in XP doen't work with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Canon MP620) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Then just save it as a GIF or a JPEG and send it as an attachment.
Hope that helps.
Chris (ziraffa)
Jan 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Scanner problem
I presume your new laptop came with Vista and your old one had XP. Either convert your new laptop to XP (complicated but I wish I'd done it when I got my new computer rather than soldiering on with the indescribable rubbish system that is Vista), or install all the latest drivers, and MP Navigator. loads of the other stuff on the canon installation disk just won't work with Vista. If you have Omnipage SE installed, you will have to get an email link from Canon, whose support website leaves a lot to be desired.
Or go to canon europe whose site is not as good (weird to see Canon not going for the simple idea of global support)
I just bought a new full version of Omnipage, but it does annoy me that so soon after buying the MP780 I had to go to all that trouble.
Nov 04, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Pixma mp520 scanner won't scan
I emailed Canon Tech Support (after searching their MP FAQ) and received this response. It worked for me:
Please follow these steps to set the push button event for the MP520
1. Click on the Windows button and then Control Panel.
2. Double-click 'Scanners and Cameras'. For Vista users, if 'Scanners and Cameras' is not listed, click 'Switch to Classic View' on the left and then try again.
3. Double-click on the MP520.
4. Next, click on the Events tab.
5. For the 'Send to this application' option, select ScanGear driver, MP Navigator, or imaging application you would like to use for the scan button event in the list.
6. Click Apply or OK to save your settings.
Jul 16, 2008 | HP PSC 2110 All-In-One InkJet Printer
After you scan your pictures, save your pictures to your computer. after that you can open your email add. Click compose message to your email add and then click attached files then browse the pictures and upload it. After that you may send your email add to your own email add and also to another email add.
May 05, 2008 | HP LaserJet 3030 All-In-One Printer
Scanner Problems After Installing Windows Vista
ya its vista issue i have same one my dell works half butt most of tiem also cuse of drivers aint relly made for vista keep looking on dell site for new vista drivers only ever other week its updated ok
Feb 03, 2008 | Dell A940 All-In-One InkJet Printer
HP Photosmart 2575 All-In-One InkJet Printer Logo
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
