Question about Neff B1421 Electric Single Oven
After use the clock display turns itself back to 0.00. The oven is working properly but this problem seem to happen when the oven is cooling
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
Aug 20, 2011 | Jenn-Air Electric Single Oven
When you press bake it reads function not avaiable press help. the oven will not turn on but the display panel seems to be working
Unplug the oven or turn off the circuit breaker for 30 minutes. .When it comes back on press cancel,then set the clock and try again.
If it still fails to work you will have to replace the EOC electronic control(clock).
Jan 03, 2010 | Jenn-Air Ovens
Display is flashing0.00 and auto. oven won't work
Try turning the oven circuit breaker off for a minute then back on. Reset the clock and see what happens.
Nov 22, 2009 | Fisher and Paykel AeroTech - OS302M...
When turning the oven on it will not start up
Assuming the clock/timer has not been accidentally set, and this is what is turning it off, does everything go off on the oven including the lights and the display on the oven control?
If it does, then it could be the oven overheat thermostat kicking in.
Also is the cooling fan running normally in the background because if it isn't, this will cause the oven to overheat.
Nov 13, 2009 | Stoves 720EF Electric Double Oven
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
Thermador oven problems
Greetings, this JUST happened to me.
The solution was to break the circuit at the breaker panel for 1 minute, reset the clock, and the unit seems to work now.
Nov 20, 2007 | Thermador Ovens
Neff B1421 Electric Single Oven Logo
53 people viewed this question
Top Neff Ovens Experts
Paul Carew
Craig Butler
Craig Butler
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
