My Rinnai Convector 400 alarm keeps going off ???
Has worked fine in the past. Last night after being on for an hour or so the alarm went off. I let it shut down then restart and it gets going but at intervals before the alarm goes off again. The room has ventilation and the rear mesh intake cover is clean so I'm at a loss....and getting cold !!! Any help would be appreciated ! Thanks !
SOURCE: Rinnai Convector 406TR
press and hold the child lock button until it beeps...
Posted on Jul 10, 2008
SOURCE: Rinnai Convector 516TR Heater
Hi, Here is the link to the manual. I think something like 'thermo coupling' probably means you need a technician!
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/153.pdf
Posted on Aug 25, 2008
taran_2005
  • 10515 Answers
SOURCE: manual for rinnai convector 516 thankyou
The manual would be
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/152.pdf
Thanks for using Fixya.
Posted on Mar 10, 2009
SOURCE: Rinnai freestanding Royale ETR flame fire (mains
I had the same problem with this unit and had the heater serviced which fixed the problem. The problem is caused by the pilot flame not being big enough to keep the thermocouple hot, so the heater thinks the flame is out and it turns the gas off! The thermocouple is effectively a switch that is on when hot and off when cold. The pilot flame is supposed to keep it hot, so its on and the main burner will get gas. When its off (ie cold) gas is blocked from the main burner for safety reasons! This manual is for a very similar heater: http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/171.pdf
You need to get at the pilot and clean it out!
David
Posted on Jul 14, 2009
  • 12 Answers
SOURCE: Rinnai Energysaver 1001FT, ignites, blows 5mins then shuts down.
Sounds like it is reaching high limit...either the filters on the back are plugged, or the manifold pressure isn't adjusted properly. IF the exhaust were plugged on the unit, it wouldn't fire at all, since it has a pressure switch to verify vent flow. The slightest blockage, the unit will lock out to prevent damage to the unit.
Posted on Sep 14, 2009
Evinrude 40hp outboard
First, the over heating alarm is for YOU to shut the motor down...
Replace the water pump assembly..(have a different mechanic do it!!!!!!!!!!!!!!)... they are NOT all created equal!!
May 17, 2017 | Boating
2008 Mercury Mountaineer electrical issues
This is a devious problem which could lie anywhere. So many things not functioning would perhaps be a ground problem. Maybe take some extra care in cleaning the battery terminals, check if the ground wire is connected to the chassis. Do you have rodents in your area? Maybe they nibbled some wire somewhere?
Jan 28, 2014 | Mercury Cars & Trucks
The alarm went off and shut down my car how do I restart it?
you may check the fuse of your car,if you are not fixed the set belt may alarm again or in short you're fasten your set belt.and the other one your door not to much close,and you can cut off the wiring's of alarm.and that's the last option.
Jun 05, 2013 | Omega NEW K-9 VEHICLE ALARM SYSTEM W/...
The alarm on my 2000 range rover keeps going off
Maybe a window is not shut properly or sun roof.
Aug 05, 2017 | 2006 Land Rover LR3
I was driving my car the other day and it turned off completely.
The most likely cause is a broken earth wire and or bad connection
Jul 10, 2009 | Chevrolet Lumina Cars & Trucks
Cannot get alarm to go off and car wont crank. 1997 Accord
It ended up being my alternator. No one could figure it out with stantard know-how, i had to take it to a Auto Parts Store for a load test on battery, they found the alternator was pulling battery down and causing alarm and security to enable start-up. Thanks for getting back in touch with me.
Jun 03, 2009 | 2004 Honda Accord
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
