Question about HP Deskjet 6940 InkJet Printer
HP Deskjet 6940. Carriage is stuck in park position. Won't move either automatically or manually. Is there some way of "unsticking " it??? Appears to be mechanicaly retarded
    President:
  • 2,306 Answers
Sometimes you can reach under the printhead with a pencil or screwdriver tip and push back the cleaning assembly. That allows you to clean the cleaning assembly so it might not get stuck again. You need to find something solid to push on, directly under the print cartridges. You will hear the motor turning as you push gently.
Posted on Aug 10, 2009
Hp 6940 printer has flashing resume and power light, no paper jam and carriage seems to move ok....
Check the Encoder Strip (metallic) that runs the length of the printer in the back of the carriage. If it is loose the carriage will not line up correctly in the printer and cause the lights to flash. On the inside right of the printer behind where the carriage sets when you change the ink look to see if the metallic encoder strip has come off the hook. If so simply reattach it to the little metal hook and the printer should start working again.
Sep 14, 2010 | HP Deskjet 6940 InkJet Printer
When I turn on my printer, the piece carrying the
This is known as 'carriage jam' and this cannot be fixed from your end.
You amy call 1 800 474 6836 (toll free) to get an upgrade.
Jul 16, 2010 | HP DeskJet 810c InkJet Printer
It comes up with a paper jam error, there is no jam but it won't let me print
Well. In this printer there is a sensor for detecting papers. That is built in to Carriage which we put cartridges. This sensor may got durt or jumped out now. You can access it by opening the door, Then look at the right side of the carriage. You will find it, very closer to carriage moving rod. If it is already jumped out, you may see some copper lines with an empty connector.
Jan 20, 2010 | HP Deskjet 6940 InkJet Printer
Carriage will not move--fixed to right
Hi, i think the motor and belt that drags the ink box is weak and needs replacement, all you need do is to get a technician that will help with the repair and replacement of those items that are faulty.
Compliments and wish you best of luck.
Dec 27, 2009 | HP Deskjet 6940 InkJet Printer
My HP Deskjet 6940 printer won't print
the printer needs servicing.the steel rod on which the cartridge carriage moves sometime oiling that steel rod makes it proper other wise the whole printer needs to be opened and the cleaning and servicing needs to be done.
Mar 02, 2009 | HP Deskjet 6980 InkJet Photo Printer
Streaky print
defective carriage. machine is brokeded (pronounced BROKE-DEAD). part unavailable, cannot be fixed, if machine is still under warranty then either take it back where you bought it or contact HP for replacement.
Oct 02, 2008 | HP Deskjet 6940 InkJet Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
HP Deskjet 6540
The color cartridge sping was loose. I am in the process of super gluing it into place. Hopefully it will work.
Mar 19, 2008 | HP DeskJet 6540 InkJet Printer
Hp deskjet 6980 blinking lights
ok so for this situation you have to do a cold reset, and by this you have to go ahead while the printer is still power on, disconnect the power cord in back of the printer, and wait for about two minutes. power on the printer if printer still has the blinking lights then go to step 2.
step 2-after this check the printer if light are still blinking, then your going to remove all printheads, remove paper, and then unplug printer power cord from printer and also from the wall outlet, wait for 20 seconds, then power on the printer, wait for light to flash then install the printheads, put paper, and press the resume button.
*** always connect your printer to a wall outlet never to a power strip, the power strip robs some of the power from the printer***
and this should fix the problem if it doesnt then the carriage might me malfunctioning . hp recently did a recall on some printer with the 6940 and some of the 6980, that the carriage broken.
Hope this help!
Nov 27, 2007 | HP Deskjet 6980 InkJet Photo Printer
HP Deskjet 6940 InkJet Printer Logo
490 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
