Question about Gestetner Office Equipment & Supplies
Gestetner 5307b motherboard problem, cannot print, im looking for the board to replace it. Hope you could help, thanks.
colliewob
  • 781 Answers
SOURCE: 6382 motherboard
http://global.msi.com.tw/index.php?func=downloadindex
go to the above site and search for the information you need
sorry this is short but you need to input the information in yourself as it requires model number type etc
Posted on Jul 25, 2008
eduy
  • 22 Answers
SOURCE: p4t533c asus motherboard died (RIP)
check the power supply...use anther outlet to plug the power cord..
Posted on Aug 28, 2008
fixyathing
  • 341 Answers
SOURCE: ASUS P4S533-MX Motherboard
Does it have a built-in system beep buzzer? or else you need to connect one. The system beep has a code and will tell you if your video is not connected or your memory is not detected.
Try to make it boot even until the bios screen. Check your video card or your monitor connector. A single beep is a good sign that your motherboard has no problems. hope this helps
Posted on Sep 25, 2008
  • 100 Answers
SOURCE: looking a used 3018gz gateway motherboard
Try www.ebay.com
Posted on May 27, 2009
  • 569 Answers
SOURCE: im looking for a charger board for a dell 1525 is
This machine does have a separate charger board that plugs onto the motherboard, held by two screws. The charger board accepts the power cable and also has two USB sockets. (top right on the laptop when looking from above)
The board is available, Part number 48.4W006.021, cheapest on ebay. It does require disassembly down to removal of the motherboard
What exactly is the problem you are trying to solve.
Posted on Dec 08, 2009
Im looking for a power supply for a 60 inch sharp tv model LC60LE810UN
Check this LINK. Please verify the actual part no of your board that is printed on the white sticker on the board itself to ensure that you will get the right board for your unit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 15, 2011 | Sharp LC60LE810UN 60 in. LCD TV
Do You have anyone in the ocala florida area that services gestetner cpoy machines?
Look for a copier dealer or service center that is listed as repairing Ricoh, Savin or Gestetner. They are all the same machines. In other words your Gestetner copier is made by Ricoh and Ricoh Dealers are far more common and easy to find than Gestetner. If you need to know the exact model then just reply with your Gestetner Model number and I can tell you what the Ricoh equivalent number is.
Hope this helps.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 08, 2010 | Gestetner Copier
Need a diagram of board
Click on the link below for the full motherboard installation and motherboard layout manual.
http://www.scribd.com/doc/13159820/KM2M-ComboL-MS6738-Manual
Regards.
Jul 23, 2010 | MSI KM2M Combo-L (MS-6738-010) Motherboard
Replace photoconductor unit
take all paper out. check to see if any paper is jammed in the rollers
go to application folder for your computer, dbl click icon for make of printer, for settings, check to ensure everything is order.
lastly, check make of printer trouble shooting web site for more information
hope this helps, good luck.
Apr 29, 2010 | Gestetner DSm725 All-In-One Laser Printer
Can't select 'Bypass Tray' as a print option.
That's strange. I just downloaded it to see what might need to be done, and the bypass tray was available, and it's a standard feature, so it doesn't have to be manually added or anything. I, however, used the Ricoh driver which is identical, because Ricoh owns Gestetner (in case you didn't know) so you may try installing that one. maybe it's a glitch in the Gestetner driver package. The comparable model is Ricoh AP 4510, and you can get it here. I hope this helps:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/p4510/p4510en.htm
Please rate me :)
May 27, 2009 | Toshiba Estudio 200L Copier
6382 motherboard
go to www.us.msi.com to request help from manufacterer with this problem. you can email help requests.
May 24, 2009 | Computers & Internet
Need wiring diagram as i had to recase
You can dload that manual in pdf format at the MSI website here:
http://global.msi.com.tw/index.php?func=downloadfile&dno=3536&type=manual
Pages1-4 and 1-5 are the pages you are looking for.
Hope this helps and thanks.
Please rate
Sean
Mar 30, 2009 | MSI MS-6378 Motherboard
IBM 300PL Mother Board
hi! im josh may i help u? i bought one of that. you can buy that at HMR surplus center in cebu near city hall and if u r in manila pioneer st. cr. reliance st.mandaluyong city or you can browse their web at hmr.ph./ to look for the branches near you.you can have the prices too.hope it can help u.good luck!
Feb 08, 2009 | IBM 11L1619 Motherboard
Version mother board?
This should be the drivers for 90% of the P4M Boards .
http://drivers.softpedia.com/get/MOTHERBOARD/Others/Via-VT8231-VT8233-VT8235-VT8237-Motherboard-36.shtml
Oct 16, 2008 | EliteGroup P4VMM2 Motherboard
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
ap-it
ap-it
jmartin50
Level 1 Expert
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
