Channel 2 goes fuzzy same time each day
At the exact time every day channel 2 will just lose signal (will go fuzzy) every other channel works but it will not (a few minutes later it returns to normal)(the other TV in my house still work for channel 2 at the time this one does not) do you think you can solve this odd problem?
  • 3 more comments
  • ripcurl_5394 Jul 17, 2009
    that could be the problem but it has been happening for about 3 weeks now
    That could be the problem but this has been happening for 3 weeks now and the other tv in my house that is running to the same place(they both run off the one aerial on top of my house) still works at the when this one is fuzzy.
    thank you for your input
  • ripcurl_5394 Jul 20, 2009
    thank you very much this has fixed my problem :)
  • 42 Answers
This may be an issue with the broadcast. As all other channels are fine its not the tuner or TV. The broadcasters may be doing work on this channel at the same time every day.
I would advise contacting the people who broadcast TV in your area
Posted on Jul 16, 2009
  • Siobhan Mack Jul 17, 2009
    Although you are using the same aerial, the two units wont necessary recevie the same signal. Try connecting the aerial to this TV only and see if this helps. You may want to try retuning the channels as well.
My panasonic TX37 lzd 80 tv has on screen message no signal on some freeview channels and the picture is fuzzy
Change your main board but before check if the power supply is ok. Good luck,
Serge.
Feb 26, 2016 | Panasonic Televison & Video
I have a logik tv and have accidentally deleted 2 channels how do I restore them ?
You'll have to go to the menu and rescan for channels again. If you have cable this should be no problem. If you are using an antenna for over-the-air signals, you do potentially run the risk of losing other channels as those signals come and go and are stronger at times than other times. If it happens, you'll just have to rescan again, possibly at a different time of day or day of the week.
Jun 13, 2014 | Televison & Video
Cable picture is fuzzy
Call your cable company as there might be a problem with the drop line or aerial coming into your house. now another thing is if you have a signal splitter( ex: 2-way, 3-way, 4-way) before the cable box, that could be degrading the signal as each input may drop the signal significantly. remeber, don't use too many splitters as they will make the signal faded/fuzzy. also, make sure all the connectors are clean and are not badly bent or the ends frayed. If you can see wire insulation from the cable line then it's no good.
Apr 05, 2010 | Insignia 42" LCD Flat-Panel HDTV
TV Cable card slot loses signal immediately after channel find
may be tv main board problem ..if you can switch  cable HD  box you can  save money
Jan 08, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Am loseing channels every time i scan the tv some channels come correctly others apparently havent signal orignally all local channells came in perfectly now a couple channells come in perfectly when...
Depending on the signal strength of those channels on the days you do the scan your tv may decide that it is not a good enough signal for it to even bother programming into your normal channel list.
The weather will honestly have a lot to do with pulling in over-the-air broadcasts.
Nov 04, 2009 | Vizio L32 32 in. LCD HDTV
Mitsubishi VCR model HS-U430. Cable channels 2-6 fuzzy.
Looks that way,the signal is not getting through the vcr,time for an upgrade
Sep 15, 2009 | Mitsubishi HS-U430 VHS VCR
Winegard digital to analog RCDTO9A
This is in an RV I gather? You do realize even with 2 converters, you may only be able to watch 1 channel at a time, as in same channel on both TV's?
Jun 26, 2009 | Audio Players & Recorders
Fuzzy tv screen that says lost signal (no dishnetwork signal)
Here are a few suggestions,
*Check your connections to make sure none are loose.
*Try checking the Dish box to make sure everything that should be turned on is actually on.
*Also make sure channel 3 is the correct channel by contacting your service provider.
I hope theis solution is helpful. Please take a moment to rate this solution.
Feb 12, 2009 | Televison & Video
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Off air digital signal
What brand of tv is it ? You could have a bad tuner or a change in the voltage supply line feeding the tuner . What type of antenna do you have ? outdoor or rabbit ears ? Also does it retain the channel line up or does it clear them as well ?
Feb 27, 2008 | RCA HD52W66 Projection Television
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
