Question about Style & Co DP Style FT006-S08 Tanneli FT Mini Toiletry Bag - Clear
Toilet problem i moved into myhouse 3 years ago the toilet was fine for about a year since then it keeps blocking I have the plumber out about 4 times they have lifted the manhole pushed rods down it clears the problem for a while then the problem comes back. i now have brown spots on my kitchen ceiling underwhere the toilet in the bathroom is. Pleae any advice I amat my wits end Ikeep plunging every couple of weeks. Not sure what the make of the toilet is.
  • 32 Answers
Your getting build-up in your pipes thats why it clears and then comes back, Make sure that you or anyone is not putting hair or anything else besides toilet paper in it and try flusing a big bottle of chlorox bealce down it 2 times a week and also use a very good drain opener.
Posted on Aug 03, 2009
Testimonial: "Very helpful thank you"
How do you know if a toilet should be replaced?
Your toilet should be just fine,I have 2 toilets that run to a septic tank,the newer one gets clogged up cause of the new regulations that only 1.2 gallons is used per flush which means it needs to be flushed more often than the old type I have,the new one,they are problematic.On your case,are you using a lot of paper,if so,then flush more often.Your plunger may have a pin hole in it,not letting you unclogged,Flush toilet,then plunge quickly.You may need a new plugger,they have better types now,Walmart has them.
Aug 20, 2017 | Home
Toilet wont flush
Main 3 (or 4) inch drain under the toilet is clogged. Requires removing the toilet and running a "snake" down the pipe. Alternately, you can (carefully) try manually filling the toilet bowl all the way to the top----to apply pressure to the clog....it may push it through.
Mar 04, 2014 | Home
My toilet doesn't flush every time I flush it! It only flush If I pour a little more water into toilet bowl while water coming down toilet bowl! I've checked water level in tank and it was full...
I think the problem with your toilet bowl is in the tank fitting of it..you better check if the fittings are proprerly working..You also check the flapper and also the fillvalve.
If it is not good already you can replace it by buying the tank fittings at the hardware store..And you better also be check it to your plumber for the second thought..
Jun 17, 2011 | American Standard Home
My Cadet 3 toilet worked fine for a year. A plumber fixed a leak at the intake line. Since he left the bowl does not fill with enough water. This causes water to splash when I flush. The flapper has a...
thumbnail.aspx?q=411971824072&id=9a63c0e833b7cdbd3aca7d8622bc1566&url=http%3a%2f%2fwww.askmehelpdesk.com%2fattachment.php%3fattachmentid%3d14345%26stc%3d1%26d%3d1228681261
This is diagram of a typical toilet tank setup if the refill tube is not putting water into the flush valve as pictured the toilet will do what you have described.
Feb 12, 2011 | American Standard 4112.016 Cadet Toilet...
Our Dual-flush toilet won't fill with water after being flushed; it h=just keeps running constantly, wasting water. This also happened a year or so ago; a plumber replaced the internal; float with a newer...
It sounds like a problem with the flapper valve. You will need to puchase a new flapper valve for your brand of toilet or that matches the one currently installed. Thihs video will demonstrate what can be a simple and esy soultion:
http://www.youtube.com/watch?v=Suno4wxDNk0
Trust this is helpful. Please Vote. :)
Dec 18, 2010 | Home
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
Poor flushing
Make sure the water level is the same in both tanks, so you know the water volume will be the same for both units when flushing. Next, hold the handle down for the full flush release to make sure the flapper (in the tank) is not closing too soon and cutting off the full water volume needed. Next, would be to get a tolet snake reamer (buy the cheapest one) and run it through the toilet bowl 3 or 4 times always turning clockwise while entering and while removing. If all this does not cure the problem, then you probably have a defective toilet outlet hole that was made too small when the toilet was formed. The outlet hole must be minimum 1 5/8 inch diameter (most are between
1 3/4 inch to 2 1/4 inch diam.) . This is an occassional industry problem; I have seen it several time over the many years. To confirm this, you need to remove the toilet and measure the hole, or get flush balls of 1 5/8 inch with 4 ft. string attached. If the ball flushes and takes all the string slack, then the hole is at least correct minimum size. If ball does not completely flush after 3 tries, then there is some obstruction or the hole is too small and toilet it therefore defective. Goodluck, Macgivor
Jan 27, 2010 | Pegasus Technologies Elongated 2 Piece...
Toilet problem
sometimes it's a simple as the paper you use.double and tripple ply will do this to an older toilet everytime.I'm a plumber for 20 yrs,this is always the problem.
Jul 15, 2009 | Plumbing
Toilet sounds like it is flushed or water filling up in the tank.
if the toilet has a 'flapper' is there slack in the chain connecting it to the flush arm? The flapper life is usually around 4 years or so - replace it if older.
Mar 13, 2009 | American Standard Prairie Field Single...
Toilet pan installation procedure
Hi muller2012,
I'm Harvey the Master Plumber.
Your question is: the procedure to join pan to waste pipe without leaking. do i silicone around rubber seal?
In 30 years this is the first time I've heard of a toilet "pan". If you're refering to the bowl, it connects with a wax ring and a pair of bolts. You then caulk around where the bowl meets the floor to keep cleaning liquids from getting under and getting stinky. If this is not a standard toilet it would be a good idea to post pictures and give make and model.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Oct 14, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Style & Co DP Style FT006-S08 Tanneli FT Mini Toiletry Bag - Clear Logo
47 people viewed this question
Top Style & Co Sport & Outdoor - Others Experts
Bill Eager
Are you a Style & Co Sport and Outdoor - Other Expert? Answer questions, earn points and help others
