I have intel D(R)2.50Gb.memory 800mb and ASRock motherboard and, western degital dard disk drive WDC WD800AAJS. When i was reformatting on the drive the processing of the formatting is only got 74% and it is not continuesly from 100% for formatting it is stop until 74%..I wait four hour but is nothing.. I turn off computer then it is not appear the logo of windows...It is appear blue screen and message is INF file textsetup.sif is corrupted or error...dectecting. plz.. help me...
  • 13,433 Answers
The hard drive is most likely faulty, you will have to replace the hard drive, partitioning it again won't fix such a fault in the hard drive.
Posted on Jul 15, 2009
    President:
  • 1,383 Answers
Delete all partition then create new partition then format it then it fix the error on harddisk.
How update wd800aajs-00b4a0 firmware ?
I do not believe it is possible to update the firmware on this model of drive. You can check on this WD website what software drivers and utilities are available for your model.
WD Support Downloads SATA SAS WD Blue SE SE16 SATA II Availability of firmware updates for WD Products
Aug 12, 2014 | Western Digital WD800AAJS-00B4A0
Wdc wd800jd-75msa3 not reading disks
A Western Digital WD800JD-75MSA3 is a 80GB hard drive.
The usual cause of read failures of a DVD ROM is dirt in the device.
Try a cleaner disk.
Jan 21, 2014 | Western Digital WD800JD-75MSA3
Blue screen of death
usually blue screen is shows when there is a problem on your computers memory on your hard disk drive,first try to clean the memory by using a clean paper on the contacts of the memory that is usually copper in color then after cleaning if the blue screen comes again try to replace a good memory if the blue screen appears again then try to reformat the hard disk drive which is the final solution to your problem.. hope this helps you
Jul 25, 2011 | Asrock P4I45GV R5 Motherboard
I add 4 GB (4x1GB) DDR2 (333/667) dual at Asrock conroe xfire-esata2 / i945p /Intel(R) Core(TM)2 6600 2.4 . i update bios from P 2.00 to P 2.20 the problem no solvied bios see 1024 MB (266/533) at any...
If you've got 4GB of RAM, then you'll only see something link 3200MB because about 800MB may be shared/ dedicated for video OR it may be because 32 bit Windows Operating can't access 4GB Memory fully.
For further details about your CPU and Graphic processor, I suggest that you download two small free utilities
Click here to download CPUz
Click here to download GPUz
These usefull utilities will provide you all the additional details.
Good Luck!
CreativeTECH
Apr 13, 2011 | Asrock ConRoeXFire-eSATA2...
What Jumper Setting Do I Need To Use A WD800AAJS As A Slave Drive?
look closely at the back of the hard drive, in small print it should say where to put the jumpers to make it a slave
Mar 12, 2011 | Western Digital WD Caviar Blue WD800AAJS...
I need driver for my WD1600AAJB
Hard disks don't require drivers.
Please explain the problem you are having and someone here may be able to help you.
Include what OS you are running, type of motherboard you are connecting it to , etc.
Feb 24, 2011 | Western Digital Caviar SE WD1600AAJS 160...
WHERE SHOULD JUMPERS BE SET ON WD1600 SSC / PM2 /OPT1 /OPT2 ????? USED AS A SINGLE DRIVE
hi wiggbone
Western Digital is usually given a choice, do not put the jumper to set the disk to a single drive / master, or you can refer to the stickers that were pasted on the hard disk
thanks and regards
Dec 08, 2010 | Western Digital Caviar SE WD1600JS...
Booting
When it come to deleting partitions or adding partitions I suggest you download WD's Data Lifeguard Tools. WD's User manual;
http://www.wdc.com/en/library/other/2779-001005.pdf
The object is to setup you're partitions in DOS mode by creating either a bootable CD or a bootable floppy disk. Using windows is not always the best way.
Same for you're Samsung drive, ES-Tool;
http://www.samsung.com/global/business/hdd/support/utilities/ES_Tool.html
Once completed installing you're operating system should be simple. Be sure to check the boot order in you're bios before loading you're OS.
Mike
Jun 06, 2010 | Asrock ConRoeXFire-eSATA2...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
