Question about Samsung LN-S2651D 26 in. LCD Television
Husband set up on wall mount connected turned on i believe menu or setting of some sort came up, he said to do with time he didn't do anything came back couple hours later now when button pushed on it briefly get a lighter screen like to come on then just goes off and is black.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
ON THE REMOTE PUSH THE INPUT SELECT A,B ANT-1, ANT-2 .........
Posted on Jul 15, 2009
Harbor breeze ceiling fans
There should be a setting inside the fan housing..there are usually a 3 position tab.. move one fan to a different position and corresponding remote...
Aug 29, 2017 | Hunter 27185 Remote Control
Black Screen - No Signal when connect Bluray to TV with HDMI
I just had the same issue and I believe it was because the sound bar was turned off. The solution was turning on all of my connected equipment such as my sound bar, cable box, tv, blu-ray player, and internet router. It stopped "disconnecting" after only 30 secs of being turned on. I think it was because my husband connected it to all those things in some way so the settings are set to work with those pieces of equipment. With one powered off, in my case the sound bar, the signal can't run full circle and reads as if cut off. Please excuse my nontechnical terminology.
Dec 28, 2011 | Philips BDP3000 Blu-Ray Player
Will it fit a universal fit wall mount
Most of these will. You san see the screw mounts on the back of the set and compare them the wall mount spand holes. I have mounted 19" RCA LCD Panels so I have got to believe this 32" should be able to mount on most universal wall mounts.
I hope this helps,
Skyassoc
Dec 11, 2010 | RCA L32HD31 32 in. LCD HDTV
Wont work
Don't know this particular model, but it sounds like you are just pressing the time buttons for cooking and not actually setting the time clock which is what it's asking for. Are you following the instructions for setting time as detailed in your instruction book?
Oct 20, 2009 | Whirlpool Microwave Ovens
How do you properly set head lights? They have been replaced from auto accident, on a 1997 Grand Am GT. The necessary repair's on the front have been done.
I believe your car has highs and lows on the same bulb. Park on a level surface about 25feet from a wall. Measure the height from the ground to the center of your bulb and mark that on the wall. On your headlight somewhere, it should say VOR or VOL or it may not say anything. If it says VOR, when you turn on your lowbeams, the brightest spot should line up just below the mark on the wall. If it says VOL or doesn't say anything at all, then you need to aim the lights two inches below the mark. There should be a plastic (white or black, but usually white) bolt of some sort on or very close to the headlamp that you can turn that will raise or lower the aim of your headlights
Aug 26, 2009 | Pontiac Grand Am Cars & Trucks
Cant get my stand of my tv to mount it on the wall can you help?
If you turn the set over you will see a set of screws attached to the bottom of the stand (inside hollow area). There also two screws I believe on the back of the unit near the stand area that need to come out. The stand should come off now. But do you really want to mount it on the wall?
Oh well,
Hope this helps
Skyassoc
Jun 22, 2009 | Toshiba REGZA 47HL167 TV
Lg lcd tv screen goes black but the sound still works 52lg70 screen goes blank, sound still works. i can change settings but cannot see the menu so the tv is still working there is just no picture.
This sounds like a mainboard problem. Unless you do not see a back light flash when you turn on the TV, which may mean it is an inverter board problem, this is most likely fixable by replacing the mainboard.
Jan 20, 2009 | LG 52LG70 52 in. LCD HDTV
Shuts off when switched to low and smells when running.
clean the burner and the orifice you can use a air line or blow off a vacum cleaner
Nov 20, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Jun 28, 2008 | Televison & Video
Fridge Freezer making annoying noise
What kind of a sound is it making???
May 03, 2008 | Hoover Freezers
Samsung LN-S2651D 26 in. LCD Television Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
