Question about Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura capresso the machine asks to open tap ,i don't know how
If you gind too fine, it will overload the pump and result in the "open tap" a few seconds into brew. Rinse and gind coarser to clear out malfunction.
Posted on Jan 20, 2008
The dial on the upper right is all you need to do. Turn from the coffee cup to the water symbol. Water will pour out the spigot from the frother wand so put a cup under it. Close the tap when prompted by turning the dial back to the cup symbol
Posted on Dec 21, 2007
  • Melissaashle Feb 02, 2011
    Yay this worked sooooooo well! I first tried wiping the grounds under the flap... It cleaned it.. But I still had the "open tap" ... So I rinsed probably two 20oz cups almost full and then it said close tap. Thank you so much! I have been so frustrated
Water is dripping slowly from one spout. How do I access and remove the spout assembly on a Jura Impressa F7?
Open the whole machine and you'll find the spout. Tighten up the nut there, the washer is like a tap thats dripping
Dec 10, 2014 | Jura Capresso Impressa F7 Espresso Machine
How do I descale my Jura capresso?
all the instruction manuals are on the jura website,, you can download the one you need and all instructions are there.
Dec 16, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
How can I open the back panel of the Jura coffee machine
There should be oval-headed screws in the machine. You need a special tool to turn them. I got one from the jura capresso doctor on ebay.
Nov 30, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
Filter change
this was absolutely the problem with my Jura Capressa E-8 machine. I followed instructions after changing the filter. I opened tap-machine stated that it was filling system- I closed tap when instruction. The open tap remained on because no water was filling system. I took the frother tip off and opened tap. Water filled system (container under frother). I closed tap without the frother tip. Machine Ready.... (I heated water in microwave for three minutes) I placed the frother tip in there and used a wooden skewer to ensure frother was clear of debris... Worked like a charm!
Nov 26, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
Display tap on Jura Impressa E75 say close tap, where is tap please
The tap is the dial on the left turn it, then it will turn the tap off. If it is repeating this then it may need to be decalcified.
Sep 06, 2012 | Jura Capresso Impressa E75 Espresso &...
I have problems with my jura capresso f60, it no longer makes coffee, it grinds the beans, but no liquid comes out. On the screen it says open tap, we have no idea how to fix this.
Machine thinks that there is no water getting to the machine. Majority of the time, this is caused by blockages of coffee in the brew group due to improper cleaning. I'm not saying that you haven't been cleaning it but that is usually the cause. How old is the machine? And has there been a cleaning tablet been put through it every day? Advise removing the brew group and check all pipes are clear, clean all loose coffee and check if you can blow through all of the pipes if you can loosen them. Clean coffee outlet/spout also. If the machines water is fed from a tank, It could also be a small bit of dirt has been pulled through. Hope this helps.
Mar 30, 2011 | Jura Capresso Jura-Capresso Impressa F60...
The "clean machine" edit will
How are you doing the clean cycle ?
You should put a tablet in the coffee grounds front lid.
Push the clean button on the inside front panel.
The machine will ask you to open tap and empty tray along the way.
Make sure it does the full cycle.
Jan 30, 2011 | Jura Capresso Impressa S9 Coffee...
When turned on it will prompt "Open Tap" "Close Tab"
There are two possible causes. One is easy the other is hard. So try the easy one first. Remove the grinds tray completely, and place you hand in the cavity that it normally takes up. moving you hand slowly in, feel towards the top. you will find a little flap, past that flap there is the tamper and coffee filter at a slight angle. This may be blocked, so clean with a cloth.
If that does not solve the problem (and 90% of the time it does) then you may have a small spec of dust that is stuck in the water system, this needs to be flushed and cleaned. The best place to do that is with a Jura approved center. Unless you are technically minded. Your local Jura chaps sound like they need a k!$k up their behind
Sep 10, 2009 | Jura Capresso Impressa F7 Espresso Machine
Capresso C1300 LCD stays on stating "Hot water cycle necessary"
I had one that set for 6 months that had that problem. Air had gotten into the water lines. Opened the hot water tap a few times and then removed the end of the water line that runs from the solenoid to heater block to at the solenoid end to bleed air out. It could also have been some calcium deposits that blew out with the air blocking the line. Then I replaced the end of the line, powered the machine up and it worked normally. Note: Jura Capresso and Capresso machines are complicated and it takes some mechanical know how to open them up and service them. They also have four special screws on the back that requires a special tool to open
Feb 26, 2009 | Jura Capresso C3000 Espresso & Coffee...
Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
1,475 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
