may be the battery, since all the components work off of it you need to check all connections, low battery, batterys are only good , if you have a 3 yr old battery, it is only going to be good for 3 yrs, or less, depends on how long it set on the shelf.
The
security system does not disable the starter, it only disables fuel to the
engine. In the fuse block under the hood, locate the STARTER relay. Place your
hand on this relay and see if it clicks while someone else turns the key to
start...if the relay is ok then the starter itself is faulty. Good luck, i hope this helps.
