Nowadays, message sending is the most common way to keep in touch with our friends and family. There should be lots of messages on your phone after a period of time. When you decide to sell your old Android device or give it to other people, you need to do something to prevent your privacy from being leaked.
Generally, the most common way you might consider to delete old text messages on android is to use the built-in delete function. Here are the steps:
Step 1: Open the Messages application.
Step 2: Select the message you want to delete, and then tap and hold them.
Step 3: Choose Delete from the Message options.
But you should pay attention the above-mentioned solution is not 100% safe. Even if you perform factory reset on your Android, the deleted SMS messages can still be retrieved by some data recovery tools. You definitely don't want some sensitive messages to be seen by people you don't know. If you don't want your private info being accessed by unauthorized parties, you can find a perfect solution in the following paragraphs.
How to Permanently Delete Text Messages on Android
Yolisoft Safe Eraser is a good choice if you want to make your text messages unrecoverable. It can help you completely and permanently erase all the data that you don't need on Android. No traceable footprints can be found on your phone after the erasure. It is the safest way to protect your personal information. Only a few steps are needed to safely wipe your SMS messages out of the system:
Step 1: Install and run Yolisoft Safe Eraser on your PC.
Step 2: Enable USB Debugging On Your Android Device, then connect your Android to computer with a USB cable.
Step 3: After your phone is identified, hit the "Erase All Data" button.
Step 4: Carefully read the instructions before you confirm the erase. Your Android will like brand new after that. Type "delete" in the black to confirm the process of deletion. If you have any important text messages, please back them up in advance.
How to Permanently Delete Text Messages from your Android Phone
Maybe an ios data eraser would help. If you need to delete data from your idevices completely, use an ios data eraser tool, I think that is helpful.
You can erase all data without possibility to recover them, but remember to backup them first.
MobiKin Eraser for iOS Windows Version
A good iPhone Data Eraser program can offer you 100% permanent erasure of your iDevice's data, and ensure there is nothing recoverable. And the operation of this kind of software is really easy to use, all process can be finished with 1-click. Now, let's us to check the detailed features: Coolmuster iOS Data Eraser Delete iPad iPhone iPod Data Permanently
If you cell phone is Android based, you can try Android Data Eraser software to erase all the data on cell phone, which can delete everything on your Android phone, including contacts, text messages, photos, videos, user names, passwords and all personal info. How to Erase Data from Android Phone Permanently
Erasing everything on an iPhone is super easy, just tap Setting > General > Reset > Erase All Content and Setting. In this process, you may be required to enter your passcode and Apple ID password.
You will also need to delete backups that you have created as well in iTunes or iCloud.
To permanently delete data from an iPhone, you can try PhoneClean. http://www.imobie.com/support/delete-text-messages-from-iphone.htm
Hello Bria, what kind of cell phone is it?
If you're on an iPhone and want to wipe data from it, you only need to tap Settings > General > Reset, and choose Erase All Content and Settings to wipe everything on your device.
After wiping an iPhone, your device will restart, you can hold the Sleep/Wake button to turn it off.
http://www.leawo.org/tutorial/how-to-wipe-an-iphone.html
