Oct 11, 2006 - 25 posts - ‎8 authors
They both work when I hook up the battery charger to them. ... This way,the plow lights only come on when the plow is plugged in,and ... A relay equivalent to Napa part #AR272 is good, if you give the number at Advance or Autozone they can cross reference it. 92 Dodge Dakota - 7'6" Snoway MT with DP ...Missing: 2008
? 10:01
https://www.youtube.com/watch?v=5RSFqO80cLM
May 20, 2009 - Uploaded by CentralPartsWarehse
A real plow install taking place in our on-site, full service shop. In this video we'll show a complete snowplow install taking place on a 2009 ... How much does a complete set up like this cost? ...BEST SNOW PLOWING VIDEO!
Programming Electronic Door Lock Control System
NOTE: The electronic door lock control processor (14B001) erases all
previous keyless entry remote transmitter (15K601) from memory when the keyless
entry remote transmitters are programmed or reprogrammed. The electronic door
lock control processor can store up to four keyless entry remote transmitters in
memory.
To program (or reprogram) keyless entry remote transmitter into the
electronic door lock control processor, perform the following steps:
Turn ignition switch to the RUN position and momentarily short the two
terminals of the program connector taped to the wire assembly and located behind
the glove compartment. All doors should lock and then unlock. Remove shorting
pin.
Press any button on keyless entry remote transmitter. All doors should lock
and then unlock to verify the keyless entry remote transmitter has been
programmed. If door locks do not respond, press button again (up to three times
maximum with the same keyless entry remote transmitter).
Repeat the above step to program additional keyless entry remote transmitters
into the electronic door lock control processor (up to four keyless entry remote
transmitters maximum).
Turn ignition switch OFF. All doors should lock and then unlock.
