Question about V-Moda Bass Frequence Bling Bling Black Consumer Headphones
My vmoda headphones output instrument sounds but
My vmoda "bas freq" headphones output instrument sounds but no voice unless I jiggle the wire around until the voice comes through. I tried a different set of headphones just to be sure it wasn't my ipod, but the other headphones work fine. I then stripped the insulation back to see if it was a broken wire, but it seems as though theres 3 different colors of wires, each containing many wires in each color wrapped around string inside, and i cant figure out if anything would be broken, not to mention I only expected to see two wires in there. Any advice would be very much appreciated.
3 Suggested Answers
SOURCE: In-ear Headphones
Same problem, not a 'speaker problem" from blowing them out. Try just pushing the jack until you feel resistance and maually hold the jack. You should hear "almost all the music and vocals'. Validates the transducers are ok. Some sort of wiring problem shorting to mic.
Posted on Sep 23, 2009
Grubhead
  • 5487 Answers
SOURCE: sound only comes from 1 headphone on my ipod,
Nothing if you do it yourself. Just see my tip on dealing with faulty wires/plugs on headphones and see if you can.
Posted on Oct 27, 2010
Why does my lowrey organ not make a sound after I have switched it on?
This is a generic answer for this kind of question.
When there is no sound
Check the obvious.
Is there a light on the organ indicating it is on?
  • Plug it in to a known working wall socket, switch on at the wall
  • Switch on at the organ, check light
  • Very old keyboards need a voice to be selected!!
  • Turn master volume up
  • Turn any other volumes up
  • i.e. lower manual volume
  • upper manual volume
  • swell pedals down
Sometimes a sustain pedal plugged into a volume pedal socket will mute the output, check this.
Headphones out, most headphones will turn speakers off, sometimes the headphone switch can be dodgy, work the headphone plug in an out a few times
There maybe a switch that turns off the speakers, look near the output sockets
Software volumes up, check display, if any.
MIDI instruments, check local control is ON
Still no sound?
Can you hear anything from the speakers?
Hiss or hum usually means the speaker is ok
Total silence may indicate speaker failure, but only if there is one speaker, as in older home organs, or smaller keyboards
Try headphones next, TURN Down master volume first just in case!
If there is some sound, very quiet and gross distortion then possible power amplifier failure.
If your instrument has any kind of line out as well as a headphone jack, try these.
The line output will likely be a pair of phono sockets,like you have on HiFi equipment, 1/4 inch, 6.35mm jacks, like the bigger headphone connector, a 3.5mm socket like the smaller headphone connector, or even a DIN connector on older equipment.
Connect these to the aux (or Line or CD) input on your HiFi, guitar amp or similar. (some times these outputs will drive headphones, usually you will only hear anything in the left side). If this works then it is very likely the power amplifier.
Further tests on MIDI equipped keyboards would be to see if the MIDI does anything.
If MIDI out works and there is no sound, and MIDI in makes a sound this points to local being off, buried somewhere in the menu will be local on or off, make sure it is on.
If MIDI out doesn't work then the failure is likely to be internal power supply or something else critical (not nnecessarily major).
Power amplifier failures in newer, low power, keyboards are often the power amplifier chips (i.c,s), older amplifiers may have just blown their fuses but one or more output transistors may have failed.
Cost of repair will be down to the time it takes to get to the fault, taking these to bits and putting them back can take a lot longer than the repair.!
Hope this helps, Chris the Fader
Aug 28, 2016 | Music
I can only hear static through the headphones on my Fostex MR16. The recording sounds fine when I transfer to computer, but I can't hear myself playing.
They make headphone amps that will take a line level and boost it in volume until it can drive headphones. I'd get one of those, and plug it into any available "line out" or "rec out" on the back of your Fostex. Sounds like the D/A converter section that feeds the headphone output has gone bad, and my solution will get you around that.
Nov 27, 2013 | Fostex Mr16hd 16 Track Digital Recorder
Blown speakers?
usually with a blown speaker you will get sound but it sounds like there is an abundance of paper very loose on the speaker, so if there is no sound at all try taking the box apart if you are familiar with stuff like this and check to see if there are any loose wires or blown capacitors
Jun 24, 2012 | Behringer Music
Both sides of my headphones are outputting sound however music that is supposed to be left isn't outputted at all. That is, if a song has instruments playing on the left side of the track, it won&
Are you using the 1/4 inch adapter- if so- make sure the mini plug is fully seated- you should feel 2 detents as you push the plug into the adapter- if you do not, you may be bridging the tip and ring colar with one channel and because it is not seated fully, it is not contacting the other channel at all.
Also make sure the plug for the headphones is fully seated into whatever device you are listening to. you should feel the 2 detents each time.
Apr 01, 2012 | Music
I found some pretty cool earphones... they are puregears purebeats headphones set. When I found them, the right earbud wouldn't make a sound unless I jiggled the wire by the speaker. And the left one...
The thin wire used in the leads breaks internally and there is no easy way to fix them, you could try to fit another cable to them but it is usually not very successful. Replacement is about the only option.
Mar 02, 2012 | Audio Players & Recorders
I just installed my vestax typhoon and the drivers. everything seems to be running fine but i can only listen through the headphones plugged into the controller. no sound comes through my laptop speakers....
Make sure the Windows computer has the audio output selected to use the computers output hardware.
In the control panel, under "sounds and devices" pane, VOICE tab, that the Voice playback window shows your COMPUTER's audio system AND then check the volume is turned up by clicking the Volume button right under that same window. Now do the same under the AUDIO tab at the sounds and devices pane.
Feb 11, 2011 | Vestax Typhoon USB DJ MIDI Controller with...
When i plug my skullcandy agent headphones into my ipod and my computer i can hear the music but just the instrumental and the voices are like echoes or whispers. the headphone seems to look in good...
Contact the maker they should be still covered. It sounds like an earth wire has come loose, perhaps at the plug. You can understand it further by seeing my tip on replacing dodgy cables plugs on headphones. Just click my name. Don't repair them yourself if they are covered.
Dec 01, 2010 | Skull Candy Audio Players & Recorders
When I plug my headphones into my iPod, there is no sound, unless I jiggle the cord around and do not plug them all the way in. They worked fine at the beginning, but do not work now.
I'm not certain it's not the I-Pod socket or the headphone jack that is playing up? If you can get another pair of headphones (a friends etc) and put them in the socket of the I-Pod, to test it that should clear it up. For if they don't work you know it's the I-Pod socket that's faulty.
If it's the Bose jack that's gone, you better see my tip on dodgy cable/plugs on headphones. You should be able to replace it with the 3.5mm type shown, but I think you can get the thinner type jacks.
Jul 09, 2010 | Bose in-ear headphones - Black with...
Ensoniq zr-76 no output signal on main and aux, but have output on headphone jacks?
Read around page 33 of your user manual about routing of sounds to the busses. The headphone jack is kind of an automatic thing compared to sending sounds to the aux and mains which require some setup.
Jan 17, 2010 | Music
One side is not working. The "loose" connection may be at the junction with the jack. Gentle jiggle to the area transiently restores the sound. Any suggestions.
It's definatly a fray/fracture in the wire. The only problem is these may have 2 wires in one wrapping. Meaning there is an outer wire around another casing for the ground wire or vice versa. If they are too expensive to replace then try to melt the rubber with a soldering iron and try to put a tiny bit of solder on the wire and put some heatshrink over the exposed wiring and heat with a hair dryer to secure it and keep from grounding.
Oct 31, 2009 | Bose in-ear headphones - Black with...
V-Moda Bass Frequence Bling Bling Black Consumer Headphones Logo
61 people viewed this question
Top V-Moda Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
john h
Are you a V-Moda Audio Player and Recorder Expert? Answer questions, earn points and help others
