No sound at all
The audio device cant seek my speakers....all players cant produce sounds... ive been reformatted my pc..
    President:
  • 4,070 Answers
You may have a broken speakers, replace it. might as well check the sound card if its tripping replace it.
Posted on Jul 15, 2009
    President:
  • 942 Answers
Hello!
You said that you've reformatted you PC, After you've reformatted did you install the motherboard driver, if you did not install the motherboard driver that's the cause why your speakers are not functioning you need to install the motherboard driver.
Good luck !!!
Regards
PCmania
Hi...i cannot get sound out off my atmos speakers
The other part of the equation is your source; which is not mentioned in your question.
Your player must also be able to decode Dolby TrueHD and the audio output on it set to Bitstream.
Dec 06, 2014 | Onkyo 7.2 Channel Network A/V Receiver -...
I recently had to reformat my computer back to factory standards. I had the Logitech Laptop Speakers Z205 b4 this & they worked.After i reformatted now i only get volume out of my laptop built in...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 31, 2011 | Logitech Laptop Speaker Z205 2 Speakers
Do we need an amplifier to connect home theater yamaha nsc150/e105 with TV, DVD, PC.plz explain
Yes, you need an amplifier, since the "levels" of the sound-output from each device (TV, CD-player, cassette-player, Sony mini-disk player, turntable) are not sufficient to physically move the "cones" inside your speakers, to push air around, to produce sounds.
You need "watts" of power to push air, while the devices produce milli-watts (watts/1000) of power.
Also, the amplifier is also a "decoder", electronically processing the input to produce "5-channel" (left, front, right, back-left, back-right) surround-sound output.
Sep 30, 2010 | Audio Players & Recorders
The external display stays muted and plays no sound but when I use the headphone port the sounds work. I cant get the laptop speakers to produce any sound though.
Go to control panel and go to sound and hardware (Just go to anything that says sound)!
Then go to sound and audio devices!
Go to Audio and change the default until sound comes out of tv!
Aug 28, 2010 | HP Pavilion dv7-1130us laptop
My speakers no longer have sound, even though the green light is turned on and they are plugged in correctly
There could be several small annoyances happening here. The first thing I suggest is try hooking the speakers audio (green) cable to a different sound source, such as an MP3 player, or cd player, or a portable GPS. If any of those devices allow your speakers to produce sound, then the issue is NOT with the speakers, and you need to look at your audio drivers/settings. Make sure your audio driver is installed, and make sure your audio settings are not muted. You can call your pc manufacturer to get help in determining your driver status.
May 17, 2010 | Dell A215 Computer Speakers
I have problem with my dell gx260 audio driver
hello rockerz rock, get the correct audio driver, locate the CD that comes with your PC or motherboard, you can also download the driver on the internet, use search engines, or visit driverguide.com, if you cannot produce the sound, reformat your hard drive and reinstall your OS, make sure you back up your files first.after you have a fresh copy of your windows, install the driver.
other option:
buy a USB sound card, plug the device on any USB port, plug the speakers, and wham, instant sound.
Mar 31, 2010 | Dell OptiPlex GX260 PC Desktop
Cant get any sound from pc,it says no sound device
WHAT IS YOUR PC,LAPTOP YOU ARE USING?IMAY BE ABLE TO HELP
Feb 09, 2010 | HP Sound Card
It does seem to be getting a power sound from my computer. When I plug in the jack to my laptop it does not make any sound to the logitech speakers and the sound continues to play from my laptop speakers.
You need to change the default audio output device in the audio control panel and restart the application (e.g. Media Player) you use to produce the sound.
Feb 07, 2010 | Logitech X-240 Computer Speakers
Speakers not working.
The easy way to trouble shoot sound problems is to plug the speakers into another device like a portable player and see if they produce sound. If you had sound from your portable device but no sound from your speakers then your speakers have died. You can see if the computer is producing any sound by pluging your headphones from the portable into the computer and see if you have sound.
May 01, 2009 | Audio Players & Recorders
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
