Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
SETTING I HAVE SHARP AQUOS LCD. WANTED TO KNOW WHERE I CAN FIND BEST RESOLUTION SETTING.
    Problem Solver:
  • 8 Answers
The Aquos is capable of 1080p which is the best current HDTV resolution - awesome!  The exact resolution is 1920x1080 with a 60Hz refresh rate.
Its also very capable at upscaling 720p inputs.  I've done various tests and visually there is practically no difference when watching a regular DVD and having the DVD player do the upscale, or letting the television do the upscale.
If you are connecting a computer then its a little more complicated...
If you are attaching a computer to the television then if the video card in your computer is capable of 1920x1080 at 60Hz then this would be perfect.  Personally I would rather use 720p rather than drop to 1080i as the drop in resolution isn't noticeable from 4 feet whereas interlacing causes me to get a headache after a while.  (LCD / Plasma interlacing isn't as bad as old CRT monitors that used to use interlacing - so not everyone will get eye strain / headaches from it)
The television is also good at showing other computer resolutions too although you'll need to make sure "overscan" is turned on which can cause some bits of the computer desktop to disappear off the edge of the screen...
I spent quite a while getting the DVI->HDMI working - to be honest I'm not entirely sure it was worth it and the results from a regular older style monitor connector is pretty similar...  If your graphics card can't handle the required resolutions - then it may well be worth a new card as HDTV output cards are available pretty cheap...
Posted on Nov 18, 2007
Laptop connection and setting for sharp Aquos 60LC633
Resolution set 1024*768 and Hz select 60hz and try to conect
May 23, 2014 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How to adjust for best picture a Sharp Aquos Quattron 3D LED LCD 52 inch tv. I'm having problem maintaining perferred brightness. Also when initial turn on the screen goes to channel then shuts down and...
This sounds like a setting that can be adjusted. What I like about some of the Sharp televisions is the av mode setting (preset brightness/contrast adjustments). I am not looking at the manual for this model so I'm not sure if this is an option on this television. However with this being a high end aquos model there is free assistance available to you. You can register your television at aquos advantage and chat live with an aquos advisor at Sharp's Midwest Corporate Headquarters. The agent may advise you to call in if your television need and Industry Initialization because you have to be talked through it. I advise the chat reps initially because when you call you aren't able to speak with the Midwest Corporate Sharp reps unless your call is being escalated.
http://www.aquosadvantage.com
Apr 22, 2011 | Sharp AQUOS 52in. LE820 LED LCD HDTV
I need to change resolution on my Sharp Aquos
it is most likley the setting on the cablr/sat box
Jul 24, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos Resolution
According to the manual for the TV, you need to change the resolution on the computer itself first.
The computer resolution should be 1024 X 768 at 60Hz or 1360 X 768 at 60Hz.
After the adjustment made on the laptop, then try the resolution change option.
Jun 11, 2009 | Sharp LC-32D64U LCD TV
COLOR SETTINGS FOR SHARP LC-42D62U
The best setting is in the eye of the one watching the TV the most. Otherwise the default settings aren't too bad.
Feb 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Help
Best would be hdmi next would be component, both can carry 1080p signal, but hdmi beats component as it can upscale to 1080p.
Jan 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Image set up
Yes.
Baclight 80%
Contrast 70%
Brightness 50%
Color 50%-60%
Tint 50%
Sharpness -6 to -8
OPC off
Nov 30, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
231 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
