Question about Motorola Mobility RAZR V3i Cellular Phone
WHENEVER I SWITCH ON MY PHONE THERE IS NO SIGNALS WHY?
  • 365 Answers
Signals will be received after some time after the start up.thank you
Posted on Jul 15, 2009
Buzzing noise whenever boot up/login/search/open/downlosd
Motherboards use signals a radio signals to communicate across them. Some on board soundcards pick these signals up. Try purchasing a better sound card. This might eliminate some of those on board noises you are hearing. Hope this helps.
Mar 23, 2014 | Dell OptiPlex GX620 PC Desktop
Whenever I use location function using GPS, the phone just hangs. Any solution?
  • This may not fix the problem but here are some tips that will help. When it is "just hanging" it is trying to receive a satellite signal. These are helpful tips to receiving that signal.
  1. Make sure you are outside and in the open. This is a phone and while it has GPS functions you have to be in the most optimal position.
  2. GPS units that work well have an antenna made to receive satellite signals faster than the phone antenna.
  3. Make sure you are standing still and not driving or walking fast. You have to give the satellites time to lock in on your position.
  4. Bad weather or even an overcast can effect satellites transmissions.
  5. Satellites move around and sometimes they are temporary a bit out of range.
  6. If a signal is not found try again a bit later and see if the satellites signals are being received better.
Regards, Tony
May 23, 2011 | Apple iPhone 3G Black Smartphone
My Phone S3650 shows network error whenever i dial a number or shows message sending failed when i send a message where as it is displaying full signals.i recently got it from saudi arab to another...
Go to menu -> settings -> network settings. Go to select network and set to 'automatic'. Then go to network mode and set to 'automatic'. If this doesnt work you may have to contact your mobile operator.
Mar 10, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My phone switchd off imediately whenever i switch
may be it is bcoz the battery life is over. Try by putting Nokia battery similar to phone and check if it works then please change battery.
May 06, 2010 | Nokia 3110 Cellular Phone
Nokia 3100 network signals disappear
You must change PA(Power Amplifier) IC on your phone.5-6second signal than gone is a sign of PA IC not work any more.You know that PA is an IC where phone use to transmit.I hope it help.
Jun 15, 2009 | Nokia 3100
My turn signals wont work right
replace the turn signal switch. or the turn signal assembly in the steering column
Mar 08, 2009 | 1996 Lincoln Continental
N 1650 switch of whenever i use to go on Ringing Tone option.
flash the phone with jaf using latest flash files for rh 305
Nov 16, 2008 | Nokia 6126 Cellular Phone
Motorola V3i Signals Problem
first select the network option manual & then select the proper signals.if facing same problem contact service provider.
Sep 28, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
32 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
