Question about HP Pavilion dv2210us Notebook
Hello I have an HP Pavillioon dv2210 us. It
Hello I have an HP Pavillioon dv2210 us. It will not to Windows. No video.
There is power to the laptop wit hbattery adn AC Power supply. Shows blue lighting on keyboard. Can hear hard dive start up. Reseated memory, hard drive, and CMOS battery. No joy. Connected to external VGA monitor. No video.
Checked intergrity of hard drive. Can read hard drive using hard drive caddy.
I contacted hp about this problem since i saw many other models had the same issue and were replaced.. ..this model did not belong to any free replace/free repair lists and a motherboard chanche would've cost 900+€, so i came up with a perfect solution: 1. Place the computer on top of two 2 inch high iron tubes/bricks/anything hard enough and leave a gap between them. 2. Take a sledgehammer and release all of your frustation-caused force, hitting the middle of the laptop and the gap.. 3. Go buy a new laptop and make a double check it is not a hp/compaq product ;)
Posted on Aug 28, 2009
  • HP Master
  • 32,281 Answers
You have done all the right tests and this tells me you have a faulty video card or faulty RAM. The video chip on most laptops use part of the RAM modules, take the RAM to your friendly computer shop to test the RAM. If the RAM is OK then you definitely have a faulty video card/chip which is part of the motherboard.
The fix is a motherboard replacement, but this may not be a cost effective solution, maybe better to put your money towards a new laptop/notebook.
Posted on Jul 15, 2009
    President:
  • 4,070 Answers
The lcd or screen must have a ribbon connection problem thats why it has no display, try to see a computer technician and have it replaced. hope this helps
Fan running very fast..and laptop gets warm
your laptop needs to be sitting on kitchen table or a thick book so the air flow can get to *********** board and fan want burn up.
Feb 17, 2011 | HP (344872-001) Laptop Cooler, Cooling Fan
When laptop hp g6000 is switched on the screen says start window repair (recommended)when this is activated the screen just goes blank and nothing happens. Any advice would be gratful
to avoid this, you need to run system restore on your system.
Restart your system and press "F11"
The system will begin the restore after you press F11. Just follow instructions and your system would be restored.
take care.
Jan 12, 2010 | HP Pavilion dv2210 Notebook
I have a hp laptop at the time of boot it is displaying a message error 200: fixed hard disk failure 0 and it can't boot
Could be either a bad hard drive or the hard drive controller. best way is to download the hard drive test from the manufacturer of the hard drive and test it.
Jul 12, 2009 | HP Pavilion dv2210 Notebook
My hp pavillioon dv2637tx does not display anything when i switch it on. Windows is booting up but there is no display. can you plz tell me the problem and cost to fix it.
Are you getting a beep code of one long beep followed by two short beeps,if so then I hate to be the one to tell you this but your GPU is fried, due to a faulty batch of nvidia chips that were produced.
Jun 26, 2009 | HP (5064-6630) Motherboard
Hp dv2210us power goes on but just black screen, not booting up
You could have a defective screen - a defective inverter or a CCFL lamp, follow this to determine the fault.
To determine if you have a LCD screen problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 19, 2009 | HP Pavilion dv2210 Notebook
Other devices in the device manager are marked with yellow marks
here the drivers for you laptop 530 hp download the Driver - Graphics and it should work
good look
Apr 16, 2009 | HP 530 Notebook
Locked out my laptop, forgot my password
Try starting in safe mode. If there is no administrative password, you should be able to reset the password.
Apr 06, 2009 | HP Pavilion dv2210 Notebook
My hp 530 laptop with windows vista doesn't sleep or hibernate
Sleep/hibernate is a function of the video driver. so download and install the latest video driver from hp.com
Dec 13, 2008 | Computers & Internet
How to format HP Compaq nx6310?
Hello
download windows istallers from microsoft that remove windows geneune then you can fomat the pc
Jul 28, 2008 | HP Compaq nx6310 Notebook
HP Pavilion dv2210us Notebook Logo
244 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
