Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
Adg 722 flashing start light
The start light keeps on flashing and will not start the model is a 722
SOURCE: Whirlpool ADG 957. Light for
Mine was doing exactly the same. I turned off power, held down the 2 black buttons on right, switched back on and the start button flashes intermittently. It then allowed me to change programs, just testing it now!! It started, this was more then it was doing!! lol
Posted on Jan 24, 2009
SOURCE: front light flashing
Solution to the problem:
Discovered that the dishwasher was covered by our household insurance policy. Phoned and arranged for it to be repaired or replaced (no charge). Engineer coming on Friday.
Posted on Jun 11, 2009
SOURCE: adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
Posted on May 24, 2010
SOURCE: Whirlpool dishwasher 1 year old
I have exact same problem with mine. Had Engineer out to tell me it requires new motor. The total cost would be €260. He blamed sand in water as we live near sea. By the way mine survived for 2 1/2 yrs with fairly gentle use
Posted on Jan 25, 2011
caroldon
  • 17130 Answers
SOURCE: Whirlpool ADG 642 dishwasher. The
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor .
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water .
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
For spares click On:
http://www.espares.co.uk/search/dishwashers/p/1083
Posted on Jul 14, 2011
Whirlpool dishwasher ADG 957
Try opening the door and holding the start button for 5 seconds to perform a reset. Then try to restart it.
Feb 11, 2008 | Dishwashers
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
Whirlpool dishwasher 1 year old model adg 7560/1 - green start light flashing and beeping - will only do rince cycle
Dec 19, 2010 | Dishwashers
Adg 3962 IX showing fault code f2 with flashing
May 24, 2010 | Dishwashers
Whirlpool dishwasher stuck on prewash cycle
the eprom memory is brocken,the main board must be changed.
Feb 14, 2010 | Whirlpool 24 in. ADG7952 Built-in...
Front light flashing
Jun 10, 2009 | Whirlpool 24 in. ADG6340 Built-in...
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
131 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
